prop for corvair diameter & pitch
Pappy
Post by Pappy »
Hi all what is the recommended diameter and pitch prop for a corvair engine?
I am thinking of getting a ground adjustable cause the pitch will be somewhat dependent on the HP out put of my engine. What should I see for full throttle run up RPM with the proper pitch prop? what is the cruise RPM with a corvair engine?
thanks
