Tail Wheel weight consideration?
E.Woodson
Post by E.Woodson » Sat Mar 09, 2019 8:54 pm
I recently picked up a nice antique Scot 3-24B that was priced right and cleaned up really nice. My big concern with installing it on my Piet is the is the weight. 5lbs 6 oz seems a lot to hoist up on that moment arm. Any thoughts are welcome. I'm still pretty new to the homebuilding world and not too far along on my project.
Colonel Rosa Kelb
EAB4
Re: Tail Wheel weight consideration?
Post by EAB4 » Sun Mar 10, 2019 10:50 am
I know people have used those tailwheels.
I’m using a Matco t6 which is slightly
Under 5lbs.
I think the Homebuilders Tailwheel from ACS weighs around 2 or 3 pounds.
Those are without the leaf springs though.
The plans built tailwheel assembly is probably
one of the lightest ways to go.
Post by taildrags » Mon Mar 11, 2019 12:29 am
My only experience is with the Scott 2000 and the Matco T6. I have flown both of them on my Piet and the Matco is 0.4 lb lighter than the Scott, using the same 2-leaf steel spring on both setups. On my scales, both the Scott 2000 and the Matco T6 came in at between 4.5 and 5 lbs., but from previous postings to the Matronics list, the spring and 6" Matco tailwheel setup is reportedly 4.5 lbs heavier than the plans-built A-frame and 4" wheel (info from Gary Boothe).
E.Woodson
Post by E.Woodson » Tue Mar 12, 2019 7:29 pm
Thanks, not sure which I'll end up using... a ways to go yet. Gary has been a great resource and love the look of his plane. I've been busy cleaning up some beautiful cast tail hinges. They worked out perfectly, thanks Oscar!
Colonel Rosa Kelb
Post by taildrags » Fri Mar 15, 2019 10:18 am
Wow... you polished up those hinges to a real shine!
