shock struts
Posted: Tue Feb 04, 2020 3:52 pm
by 173rd.abn.bde2426
I'd like to replace the bungee arrangement on the shock struts on my Pietenpol with springs. Any ideas ?
Re: shock struts
Posted: Tue Feb 04, 2020 7:36 pm
by Earl Brown
this article has some good info- a good place to start if you want to change over to springs.
https://flycorvair.net/2012/10/27/new-d ... a-m-4-p-m/
Re: shock struts
Posted: Thu Feb 06, 2020 12:16 pm
Thanks foe some really great info. My one question is that my struts as drawn, show them attaching to the bottom V of the gear and to the front mounting plate in one straight shot. Forgive my ignorance but would your springs work on that arrangement? My welding skills are non existent so I would sleep on the sidewalk to be first in line, should you decide to make a kit for these springs. Thanks for your help ( great pictures ).
Bill Keener
Westlake Ohio
Re: shock struts
Posted: Thu Feb 06, 2020 9:53 pm
by taildrags
Bill: are your struts set up sort of like some variation of this?
Re: shock struts
Posted: Thu Feb 06, 2020 9:55 pm
by taildrags
If so, the "spring in a can" setup should work just fine. There is a bit of a delicate geometry where the two shock struts cross each other, but you should be able to work that out by adjusting the mounting point of one or the other of the struts up at the top end.
Re: shock struts
Posted: Fri Feb 07, 2020 7:47 am
by Earl Brown
if your landing gear is built to plans, then, it could work. this plane had bungees and got changed over to springs.
These are external springs- the spring in a can version is a bit larger so clearance might become an issue.
These are a couple of images on how to make the external spring type gear.
Earl
Re: shock struts
Posted: Tue Feb 25, 2020 8:16 pm
by at7000ft
