Any one had any experience on brushing this stuff on to metal? Reading thelabel shows it is rather nasty to spray. ________________________________________________________________________________
Pietenpol-List: Polyfibre epoxy primer for metal
Pietenpol-List: Re: Polyfibre epoxy primer for metal
Original Posted By: SRXJimL(at)aol.com
You might get good results if you use an artist's sable-hair brush.Fine art quality brushes are the key to a really smooth brush-on finish.Certainly worth trying.________________________________________________________________________________
If you brush this stuff, remember to use a little more retardent so the brushstrokes can flow out. Also, brush length wise along the part, parallel to theground again so gravity can help the brush strokes flow out. Good luck!________________________________________________________________________________
Original Posted By: Gary McArthur
