Pietenpol-List: Leading edge strip material?
Original Posted By: "Egan, John"
RE: Pietenpol-List: Leading edge strip material?
Re: Pietenpol-List: Leading edge strip material?
I think dale and greg used a lot of cedar from the lumber yard.chrisBraumeister und Inspektor der Flitzer und Flitzermotoren----- Original Message -----
where did you get the wood?ChrisBraumeister und Inspektor der Flitzer und Flitzermotoren----- Original Message -----
Re: Pietenpol-List: A/N Hardware
Original Posted By: John and Phyllis Smoyer
the dash number is the length of the grip in eighths of an inch with a -1 at 1/8"grip length and a -7 at 7/8" grip length. There is no such thing as a -8 ora -18 or a -28 etc as a -8, at 8 eighths, becomes a 1 incher or, better yeta 1 incher and no eighths or a -10. So a -7 is 7/8" and a -10 is a 1" and a-11 is 1-1/8"The grip is the length of the bolt excluding the head thickness.ChrisBraumeister und Inspektor der Flitzer und Flitzermotoren ----- Original Message -----
RE: Pietenpol-List: A/N Hardware
Jack,Did I see a nice peg on the side of your fuselage to assist aperson(you) when climbing into the back seat=3F If so, would you describethe design and mounting=3F Some people have 30" in seams.... -----Original Message-----
Original Posted By:> Christian Bobka
ChrisWe used redwood for the leading edge and the trailing edge. Dale> [Original Message]
Original Posted By:> "Egan, John"
> Subject: Re: Pietenpol-List: Leading edge strip material?>>> I think dale and greg used a lot of cedar from the lumber yard.>> chris>> Braumeister und Inspektor der Flitzer und Flitzermotoren> ----- Original Message -----
