Original Posted By: Donald A Mosher
Oscar,If your plane is sitting flat, relative to it's normal condition stall speed straightahead, you may not be bouncing at all. Rather, you are simply going flyingagain.You have flying speed, you are increasing the angle of attack, but not too faras you are limited by the angle your plane sits, so she simply climbs. As thepower is off. And you are dissipating energy, you do slow to well under flyingspeed and the cycle stops. In that glastar I finally found I was able to avoid that "bouncing" by simply holdingwhat I hat at touchdown to maybe easing off the stick a little, until Islowed enough to get the stick back without going flying again. Basically awheel landing but don't have to ease the tail down, it's already there.ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 29 Apr 2016 13:08:56 -0500Subject: Pietenpol-List: Bingelis books on sale at EAA
Pietenpol-List: Re: wing stall angle
Hi Doc,I happen to own a set of them. Great resource to own. Cheers,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: wing stall angle
