Rib Construction
ELB
Rib Construction
Post by ELB »
Can anyone shed some light as to where they placed the extra bracing required for the 4 end ribs as shown in the plans. It appears to be required for the longest truss cross member behind the rear spar and at 90 degrees with gusset reinforcement. Is the intersection at some generally accepted point (say half way) on this crossmember ? Thanks. ELB.
EAB4
Re: Rib Construction
Post by EAB4 »
That's how I did mine-about in the center of the last rib bay and perpendicular to the last truss member
ELB
Post by ELB »
Thanks . I shall proceed.
