Pietenpol-List: Pietenpol near Olive Branch, MS?
Posted: Tue Feb 01, 2011 5:36 am
Original Posted By: John Ackerman
Michael Perez wrote:> Of course the rims, spokes and nipples are not cheap.Care to elaborate?- I'm looking at a couple of wheel options and I curious how they compare in price.--------Mark ChouinardWings, Center Section and Empannage framed up - Working on FuselageRead this topic online here:
http://forums.matronics.com/viewtopic.p ... 0#329270le, List Admin.________________________________________________________________________________Date: Wed, 2 Feb 2011 15:40:34 -0600Subject: Pietenpol-List: Pietenpol near Olive Branch, MS?
Posted: Wed Feb 02, 2011 3:57 pm
Original Posted By: airlion
Pietenpol-List: Re: Pietenpol near Olive Branch, MS?
Posted: Wed Feb 02, 2011 10:08 pm
Hi Ray - I'm sure Jack will answer but I'll throw in my thoughts. Those permanent fixtures are just that, permanent. The vast majority of builders cover them as Jack has. Take a look at
www.westcoastpiet.com at the dozens of close-up photos there, including Jack's beautiful airplane. If you end up having to access covered fittings then yes, you're responding to a significant issue of some sort. We don't routinely "snug" structural bolts under fabric.If you do have to get to a covered bolt to do work, you cut the fabric, do thework, and then make your patch per the instructions you'll get with whatever coveringsystem you use. The fabric portion of those repairs would likely be completedin an afternoon.Best regards,Kevin--------Kevin "Axel" PurteeNX899KPAustin/Georgetown, TXRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Pietenpol near Olive Branch, MS?
Posted: Wed Feb 02, 2011 10:14 pm
If you're anywhere near Austin when you get to TX this fall yell at me. I'll hookyou up, too.--------Kevin "Axel" PurteeNX899KPAustin/Georgetown, TXRead this topic online here:
Re: Pietenpol-List: Wire Wheel Build-up
Posted: Wed Feb 02, 2011 10:45 pm
Michael,Thanks for the info. I assume the rims are aluminum and the spokes are stainless? Double wall rims? I will weigh mine tomorrow. I think they weigh more and they are chromed metal.Thanks,Ray Krause ----- Original Message -----
Posted: Thu Feb 03, 2011 11:09 am
Original Posted By: V Groah
Hello John,Good luck in all your pursuits. You didnt list your contact info, so I am passingyou contact info (with permission) of a guy with worlds of information on severalfronts. Thousands of hours in homebuilt aircraft, airline captain, andhe heads up the Fly for Life missionary organization at Oshkosh each year. Feelfree to give him a shout out: smokyray(at)rocketmail.comAnd good luck with the Piet!Steve--------Stevewww.mypiet.comRead this topic online here:
Posted: Fri Feb 04, 2011 11:25 am
Thank you very much! To all of you! This is a great community!For an update on the "building"...I'm planning on buying the Corvair Conversionmanual, and the Flyer and Glider builders manual, today. I'm actively savingup for the plans (I'm going to get the original, supplemental, and 3-piece, packagefrom the website) and should be able to buy them in a few weeks.I'll talk to my dad, and we'll probably get in touch with Mr. Beck once we move.And I'll definitely give you a call this fall Mr. Kevin. Thanks again!Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 4 Feb 2011 09:42:31 -0800 (PST)
> --> Pietenpol-List message posted> by: "A Future Pilot" > > Thank you very much! To all of you! This is a great> community!> > For an update on the "building"...I'm planning on buying> the Corvair Conversion manual, and the Flyer and Glider> builders manual, today. I'm actively saving up for the plans> (I'm going to get the original, supplemental, and 3-piece,> package from the website) and should be able to buy them in> a few weeks.> > I'll talk to my dad, and we'll probably get in touch with> Mr. Beck once we move. And I'll definitely give you a call> this fall Mr. Kevin. Thanks again!> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 596#329596> > > > > > > > Email Forum -> FAQ,> - MATRONICS WEB FORUMS -> List Contribution Web Site -> -Matt> Dralle, List Admin.> > > > ________________________________________________________________________________Date: Fri, 4 Feb 2011 09:58:07 -0800 (PST)
