No thanks to Kevin, Tim? After all I've done? Hmmphh.....--------Kevin "Axel" PurteeRebuilding NX899KPAustin/San Marcos, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Off Topic - Douwe's Sculpture
Shelley & I in front of Douwe's exquisite sculpture at the 9/11 memorial. Be gladwhen it's out from behind the fence. The photo doesn't do it justice.FBG Update: Covering and getting ready to spray. Shelley has to get her tear droptrailer out of the garage first. Also need to finalize the engine installationand make the cowl for that.--------Kevin "Axel" PurteeRebuilding NX899KPAustin/San Marcos, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/douw ... __________
RE: Pietenpol-List: Off Topic - Douwe's Sculpture
AMAZING!! Douwe's sculpture...Shelley's trailer...and your progress onFBG!!!Gary BootheNX308MB-----Original Message-----
Pietenpol-List: Re: Off Topic - Douwe's Sculpture
Hi Dave,I just got done looking at your blog spot. I don't know what you are using toclean your engine parts. Last year I tried using Pine Sol (full Strength andit can go down the drain) as a carburetor cleaner. I worked really good and isis cheap if bought in the lager containers. Just be sure to wear rubber glovewhen you put your hands in it. I am thinking that it will work good for cleaningall the engine parts. The Carbs turned out nicely. I let them soak overnight.Has anyone else tried this besides me?--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Off Topic - Douwe's Sculpture
Original Posted By: "glich7(at)juno.com"
I don't know if I will ever get to see it in person,but it sure looks inspiringto me.--------Building steel fuselage aircamper.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
