Control Horn GA Steel thickness
Posted: Mon Jan 24, 2022 9:07 am
Hello All:
I just purchased CNC cut fittings from a place called "Icarus" (on the net). I noticed he cut the control horn material (rudder/elevator/aileron) out of 24 ga but the plans call for 22 ga. (slightly thicker). Does anyone see a problem with using his slightly thinner material? What did you use?
Thanks!
Thanks!
