Elevator bellcrank cable connection
Posted: Wed Nov 16, 2022 7:31 pm
by PoconoJohn
I'm trying to find the right part to connect the elevator cables to the elevator bellcrank. All I can find is AN115 cable shackles. They don't seem large enough to have two cables connected.
Once that's figured out, is the cable looped through as seems to be on the plans, or is there a better way?
Thank you,
Re: Elevator bellcrank cable connection
Posted: Wed Nov 16, 2022 10:16 pm
by taildrags
Are you talking about the bellcrank inside the fuselage, behind the pilot's seat?
Posted: Wed Nov 16, 2022 10:29 pm
by taildrags
Browsing around Westcoastpiet, there are plenty of different setups at that bellcrank. Here's Chris Tracy's.
Posted: Thu Nov 17, 2022 9:05 am
by PoconoJohn
Yes, that's it. I see a shackle on the top right. I'm trying to figure out how to best connect the cables. I'll look around for photos.
Posted: Thu Nov 17, 2022 10:39 am
by taildrags
John, note that you can use some AN111 cable bushings through AN100 cable thimbles to secure the cable ends to the bellcrank by passing a bolt through them. Various ways to skin this cat.
Posted: Thu Nov 17, 2022 10:55 am
by PoconoJohn
Thanks! I may be back with more questions.
John
Posted: Sat Nov 19, 2022 1:00 am
by KenBickers
John, I somehow managed to build my Piet without using a single AN115 cable shackle. I used pairs of #50 motorcycle connecting links throughout. They fit AN3 bolts perfectly and can be widened or narrowed by using however many washers you need. They are also much, much cheaper than certified thimbles, as you can buy them from places that supply drive chain systems and probably from your local motorcycle shop. I bought mine from Grainger. If you'd like, I'll snap some pictures. Cheers, Ken
Posted: Mon Nov 21, 2022 7:23 am
by PoconoJohn
Thanks Ken! Photos always help. I'll go to Grainger and look around.
John
Posted: Tue Nov 22, 2022 3:24 pm
by KenBickers
John,
I haven't found a picture of my elevator bell-crank assembly. Here's one taken of the rudder horn that might give a sense of the flexibility provided by using combinations of motorcycle connecting links. (Disregard the angle-finder. This was taken as a set of photos when I was dialing in the H-Stab angles of incidence.)
Posted: Wed Nov 23, 2022 12:45 pm
by PoconoJohn
I can see the set up clearly. Thanks!
John
Posted: Mon Jun 03, 2024 10:17 am
by dnboyd
I have a complete,behind the seat, bell crank assembly available.
Dave Boyd
217 202 3417
