Original Posted By: "Jack"
I did the same thing Rick... except my count was a little over 1000 pieces sinceI installed uprights in front and behind each spar, plus the additional uprightson the on the 6 end ribs. I probably would not install the uprights in frontand behind each spar again. It seems to be a bit much, and they were a minorpain to slide onto the ribs. I think the single uprights (or maybe noneat all as per the original plans) would probably be sufficient. I went through a dozen emery boards sanding each of those gussets before I gluedthem. A sanding block would have have required minimal effort. I'll rememberthat in the future.--------Mark - working on wingsRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
