Pietenpol-List: More mag problems
It was a pleasure to meet John for the 1st time and to get to spend some more timewith Hans and Karen. Thanks to all of them for a really nice evening. Also got to see Hans at the Critter's Lodge fly-in in Centerville, TX this weekend(a wonderful outing). Two Corvair Piets at a small fly-in in central TX.Lots of fun.Photographic evidence of the Brew Boys festivities attached.Axel--------Kevin PurteeNX899KPAustin/Georgetown, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/hans ... ___Subject: Pietenpol-List: More mag problemsDate: Mon, 27 Sep 2010 07:45:16 -0400
Ah yes=2CI have had this happen to me and when I talked to another pilot he told me it had happened to him as well.It does happen on occasion that both will go at the same time.I sent both of mine away to Savage in California and had them overhauled and the guy told me that they were in real bad shape.Both of them.I guess because most of the time we get them overhauled at the same time and they are both used at the same time it stands to reason that they should both go at close to the same time.You were very lucky to make it back with out having to land out in an emergency. Subject: Pietenpol-List: More mag problemsDate: Mon=2C 27 Sep 2010 07:45:16 -0400
RE: Pietenpol-List: More mag problems
Original Posted By: harvey.rule(at)bell.net
Another thing you should do is check all your plugs.I don't know about you but I use regular automotive Champion plugs and they are like light bulbs=2Cone minute they are fine the next they are junk.I wish i could get a cross for aviation plugs but there is no such thing for my engine.
Re: Pietenpol-List: More mag problems
Subject: Re: Pietenpol-List: More mag problemsDon't know Dan. Just happy you're home safe and ready to fight another dayJohnSent via DROID on Verizon Wireless-----Original message-----
> Pietenpol-List: Am I a Redneck?
Re: Pietenpol-List: Re: the Brew boys get together was a happening thing
Dan:I switched from Champions to AC & Autolite many years ago and never had a problem, even with a single mag. Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: the Brew boys get together was a happening thingDate: Mon, 27 Sep 2010 10:01:22 -0400
Pietenpol-List: Re: Startin' My Ribs- Tucker
Well Captain and I made up the rib jig, steam box, bending jig, and cut the gussetsso I'm finally ready to make some ribs. Here are pictures of our steam boxand jigs.Today's my birthday, I'm finally a 13 year old teenager. Whoo Hoo!--------TuckerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/img_ ... ___Subject: Pietenpol-List: Re: Startin' My Ribs- Tucker
Happy Birthday Tucker! Thanks for the update on your Piet project, keep up thegood work. Hopefully you will have it done in time to solo it on your 16th birthday!--------Billy McCaskillUrbana, ILtail section almost done, starting on ribs soonRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 27 Sep 2010 17:21:16 -0700 (PDT)
Original Posted By: johnwoods(at)westnet.com.au
Howdy,I have a Corvair engine stripped for building.Went with an O-235Correct # block,heads,crank,all parts required to keep according to WW manual,also new unused and unregistered WW conversion manual.Email me if interested.Can send pictures.69 block and cyls-68 heads all parts look to be in good shape.Dave________________________________________________________________________________Subject: Re: Pietenpol-List: More mag problemsDate: Tue, 28 Sep 2010 07:29:33 -0400
Pietenpol-List: Re: More mag problems
So the only "PMA" "aircraft" parts are the ones giving you problems ??Sorry Dan...... were the mags new? I would have thought one mag would have doneOKJeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 28 Sep 2010 07:17:30 -0500 (GMT-05:00)
Pietenpol-List: Re: Shad flying back home...
Original Posted By: jeff wilson
Hey Shad.. it looked greatI was the long hair that was all over your plane when you landed... wanted to sayhello but you were surrounded pretty quick... i noticed you on the upwind leg..recognized the piet and watched for you to park.I was in my 120..from lee bottom i took it to danville KY to its new home.I start building in the next few weeks. If you've never been to Lee Bottom you are missing a great fly injeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By:> jfaith(at)solairusaviation.com
two shouldn't go at the same time. Start looking at things in common=2C like the mag switch. Also=2C is it possible you have an engine problem like a blown head gasaket that might have fouled plugs?Gene> Subject: Pietenpol-List: Re: More mag problems
> To: pietenpol-list(at)matronics.com> om>> > So the only "PMA" "aircraft" parts are the ones giving you problems ??> Sorry Dan...... were the mags new? I would have thought one mag would have done OK> > Jeff> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 976#313976> > > > > > > ============================================> > > ________________________________________________________________________________
