Original Posted By: "Pietflyer1977"
Chris. First off, I am stoked to see your plane! Any chance of broadhead? Secondly,I modified helsper's brake design and I really like it. A toe actuatorsticks out from the fuse walls just in front of my toes, they go thru slotsin the wood to flay stock levers which lie against the outside of the ply , betweenply and fabric, their ends protrude out a slot at the bottom and a cablefrom each brake Ron's to them. All you see in the cockpit is a two inch tubesticking in, everything else is hidden. Just like dans in concept, just movedsome stuff outboard.Douwe________________________________________________________________________________Subject: Pietenpol-List: Oil temp / Water temp gauge
