> Re: Pietenpol-List: Re: Wheels=2C diameter=2C width
Original Posted By:> brian.kenney(at)live.ca
I am studying the same. How did you handle the axle diameter?Lorenzo> Subject: Re: Pietenpol-List: Re: Wheels=2C diameter=2C width
Original Posted By: brian.kenney(at)live.ca
Many thanks for the reply. I'm going to do something similar.LorenzoSubject: Re: Pietenpol-List: Re: Wheels=2C diameter=2C width
> To: pietenpol-list(at)matronics.com> > > I have honda 350 rear motorcycle wheels. They come in 18 and I believe 19 inch rims but I have the 18 inch by 3 inch tires. These rims are cheap and plentiful and have there own brakes. I use them on the wood gear with the straight axle. They have easily more than 1500 landings on them.> ________________________________________________________________________________Date: Mon, 03 Mar 2014 12:10:02 -0600
I replaced the bearings with bronze bushings with 1.5" inside diameter. The break plate is machined for a piece of 1.5" I.D. Scaffold tubing and welded in. The brake lever is shortened. I can help you thru it with sketches if you want.Sent from my iPadOn Mar 4=2C 2014=2C at 7:09 AM=2C "larharris2 Harris" wrote:=0A=0A=0AI am studying the same. How did you handle the axle diameter?Lorenzo> Subject: Re: Pietenpol-List: Re: Wheels=2C diameter=2C width
