Original Posted By: "nauus"
Steve-I used three 1/8" thick aluminum brackets to secure my windshield. I had to T-88 epoxy (scuff sandedboth surfaces) a doubler underneath the aluminum (2024 T-3 0.024") to stiffen the area since I elected to useLexan which has to be held in place and has some spring-back force. If you're using Plexiglas and areforming it or bending it to look like a 3-pce that won't apply to you.Mike C.Ohio[cid:image001.jpg(at)01CF5407.CA7DA590] [cid:image002.png(at)01CF5407.CA7DA590] [cid:image003.jpg(at)01CF5407.CA7DA590]________________________________________________________________________________Subject: Pietenpol-List: It is possible a AirCamper with a MTOW = 450 kg (992 lb)
