If you do want to use a wire coil, a good candidate is adrier element or pottery kiln element. These are alloyedto function at very high temps for years. Usually of a nickel chrome material, corrosion is unlikely.ClifWhen I was younger, I could remember anything,whether it happened or not. Mark Twain> I re-did my heat muff this winter, with much improvement made. Perhaps > something similar would work for you.>> Here's what I did: > http://www.eaa25.org/wp-content/uploads ... 201401.pdf>> Carb heat is a lot more effective now, too.>> - Pat________________________________________________________________________________Date: Wed, 4 Jun 2014 09:26:49 -0500Subject: Pietenpol-List: sealing the bottom of a hangar door.
