Pietenpol-List: Re: advice on trim mechanism
Hey Paul,I'm sure that something could be designed to work with a little thought. I havebeen thinking about your question for several hours and I am not sure why youwould even want or need one in the front cockpit. Piets are soloed from therear seat, that being said, if someone were flying it in the front seat thenI would only hope that there is a qualified pilot in the back seat to adjust thetrim. The second thing that comes to mind is that we as builders should beconcerned about any extra weight we build into the planes. It only takes awayfrom our useful load no matter how minor the weight gain. All that said, I'm sure someone on the list with a similar trim system would havesome useful ideas for the front hole. My trim system is not like any otherPiet I have seen. It is copied from a pre-war T-craft. It could be made towork from both cockpits without a lot of extra work. Respectfully,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: advice on trim mechanism
I have electric trim. Aside from Scott's good advice, it could be easilyadapted for co-pilot operation. Only thing is......I have never used it!!Gary BootheNX308MB-----Original Message-----
Pietenpol-List: Re: Piet on Barnstormers posted Oct 12
Are you putting in airspeed indication in the front too? If not, don't reallyrecommend trim, especially for front seat instruction. That way, fifty alwaysfeels like fifty, sixty always feels like sixty, etc. I taught my son to fly in the front of a Piet. Good intercom is way more important.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Piet on Barnstormers posted Oct 12
Original Posted By: George Abernathy
Charles,The ad appears to have been taken down. I saw it and they described the motor asbeing a Corvair. It did not look like any Corvair I had ever seen. I forwardeda link to William Wynne and here was his response-"Terry,I just called the guy and suggested taking the word Corvair out of the ad. I thinkit is a Pontiac Iron duke 140 cid. est. project value $3,500 if the coveringis perfect and the wood is cert spruce. Otherwise get the zippo lighter.Thank you.William Wynne"--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 13 Oct 2014 12:41:34 -0700
Gardiner,Here are some pics of mine. I can only seem to add one pic at a time so therewill be 3 post. Lets give it a try. Paul. Just a FYI, I have never flown a Piet that would fly hands off like youare hoping. The best has been for only a few seconds at a time. It is not liketrimming a cessna for various airspeeds. You may be asking too much from thePiet. My 3 cents.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/p102 ... ___Subject: Pietenpol-List: Re: advice on trim mechanism
Simple bell crank with tension spring on one side and a pull cable on the other.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/piet ... ___Subject: Pietenpol-List: Re: advice on trim mechanism
Re: Pietenpol-List: Re: advice on trim mechanism
Original Posted By: woodflier
Again with a simple bell crank with a tension spring, pull cable attached to itand a friction ajustment to hold it in position. It is a VERY effective trimtab. Sorry for the fuzzy pic but it is all I have right now. The bell crankis at the base of the throttle lever.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/piet ... ___Subject: Re: Pietenpol-List: Re: advice on trim mechanism
Original Posted By:age-----=0A AircamperN11MS =0ATo: pietenpol
At a certain fuel level, mine will fly hands off in pitch, but I have a bit more washout on the left wing than the right and without feet on the rudder bar, mine will gradually turn left. Gonna try and fix that with a new front right strut fitting over the winter, and possibly an elevator trim gizmo. =0A=0A=0AMatt Paxton=0ANX629ML=0A=0A=0A=0A-----Original Mess
Where are you on your project? Or are you flying already?Sent from an iPhone with a spelling problem> On Oct 16, 2014, at 8:21 PM, "gsnewsome" wrote:>>> Jeff,>> I'm the one that suggested the walk around video.>> Just down the street from you.>> Greg (Savannah, Ga)>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ______This e-mail message (including any attachments) is for the sole use ofthe intended recipient(s) and may contain confidential and privilegedinformation. If the reader of this message is not the intendedrecipient, you are hereby notified that any dissemination, distributionor copying of this message (including any attachments) is strictlyprohibited.If you have received this message in error, please contactthe sender by reply e-mail message and destroy all copies of theoriginal message (including attachments).________________________________________________________________________________Subject: Pietenpol-List: Re: advice on trim mechanism
She's a beauty, Jake! Looking very nice. Good logic with the extended centersectionin order to eliminate a header tank. Gravity never stops working and simpleris better.With the reduced rolling resistance you'll get with those ultra-skinny tires, I'llbet you already have enough lift from just the centersection to get you upto takeoff speed and in ground effect!--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: advice on trim mechanism
Folks; I'm not trying to shoot down anyone's favorite trim actuation setup, justpassing along another data point for consideration. On the way to the CopperstateFly-In this past weekend, a friend's Super Cub with a Bowden-cable actuatedtrim tab on the elevator had the cable break at the trim tab. The tab immediatelywent into a violent flutter and acted as a servo tab, which set theelevator into flutter sympathetically. My friend said that he thought the enginehad blown or that he had lost a prop blade, the vibration was so violent.Changes in airspeed and power setting didn't change anything so he realizedthat it wasn't the engine. His passenger had the presence of mind to suggestthat he lower the flaps, and that seemed to blank some of the airflow over thetail and diminish the frequency of the flutter enough to where they limped about30 miles to an airport.Upon inspection, the Bowden cable was found to have a brittle fracture betweenthe point where it emerged from the outer sheath and the point where it attachedto the tab, and the wire was extremely work-hardened. This airplane is a completerestoration with less than 300 hours on it, and my friend is an A&P. He's replacing the Bowden cable setup with an electric trim servo.Just passing along this information, and I see that the way the "Big Piet" guyshave theirs set up, the amount of wire outside the sheath is about as short asit can be while still providing effective trim tab travel. Shorter is better,given my friend's experience on his Super Cub.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: advice on trim mechanism
Pietenpol-List: Re: The fuse is ready!
Oscar,Thank you for this information. Being a tech counselor I like having these storiesavailable for discussion with the builder I meet with. I am very happy tohear that the fella this happened to managed to land safely. Flutter will usuallytake a plane out of the sky. I will be looking in this area of the trimsystems a lot more carefully because of your post. Thanks again Oscar,Cheers,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: The fuse is ready!
Ken, Congratulations. It looks and sounds great. Perhaps you'll get the first flightin this fall. The best time of the year for flying in my opinion anyway. I too like the sound of the exhaust. Can't wait to see it in the air.Cheers,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: advice on trim mechanism
Original Posted By:-----Original Message-----=0A AircamperN11MS <Scott.liefeld(at)lacity.or
The trim tab on the Lark glider our club used to own, and also the one on our towplane are both moved via double bowden cables, one top and one bottom so that most of the actuating is done in tension. That arrangement also provides redundancy in case one cable breaks. =0A=0A=0AMatt Paxton=0A=0A=0A=0A
Huh. Did Lindbergh have all that stuff when he made the crossing? He flew itin 1927, the Piet is a 1929 design, I'm claiming that because they are from generallythe same era, the same rules will apply. Either that or I'll make thecrossing below radar coverage, land in the first suitable cow pasture "over there",and then cover the US registry markings with UK markings in white ducttape. I'm going to use "G-BUSH" or something else that doesn't attract attention;o)Move over, Steve... I'm ducking into the same foxhole...--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: advice on trim mechanism
Some more general ponderings about trim and a question.For most of the around-the-patch flying I do, in level "cruise" flight, I "trim"with the throttle. If the nose is dipping, I bump up maybe 50 rpm (usually less).If I detect a slight climb, I pull the throttle back just a little. Thedifference in airspeed is usually less than 5 mph. I don't really need a trimmechanism for this.Where I would like trim is on climb-out, where I need to push forward on the stickif the fuselage tank is less than 3/4 full and there is no passenger, andon base and final, when I've pulled power back to idle and I need to pull thestick back quite a bit to keep the nose up and maintain 50-55 mph.For all those who have a trim system on their Piets (Scott, Barry, Gary, and others),does your trim system work with enough power to, say, maintain a steadyairspeed while on final? I find that final is the most extreme (relative, ofcourse).Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: advice on trim mechanism
Not to muddy the waters any more, I saw this Pietenpol at the Hiller Aviation Museumin San Carlos CA yesterday. The pulleys seem to complicate things and Ihave no idea what the top of the trim tab looked like or the cockpit controlsas the airplane was about 15 fett over my head.--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/imag ... ___Subject: Pietenpol-List: Re: advice on trim mechanism
Pietenpol-List: Re: Request for Latex Paint Projects
Terry: is that the museum with the Long EZ on the roof? Friends have told me it'sworth visiting.I see what you mean about the added complexity with the pulleys. I can only imaginewhat this setup would do if the cable broke.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Request for Latex Paint Projects
Malcolm;I don't have a latex paint project per se, but I do have a test setup that I wasworking on, in case you want to include a link to it:http://www.flysquirrel.net/piets/paint/paint.htmlI still have the test coupons and I need to set them up outdoors to see what ayear of weathering does to them.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: advice on trim mechanism
One and the same museum. If you are ever in the area you should stop by not big,but it has some interesting exhibits.I like the double Bowden cable idea, FWIW.--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: advice on trim mechanism
jarheadpilot82 wrote:> Not to muddy the waters any more, but I saw this Pietenpol at the Hiller AviationMuseum in San Carlos CA yesterday. The pulleys seem to complicate thingsand I have no idea what the top of the trim tab looked like or the cockpit controlsas the airplane was about 15 feet over my head.Actually, for a retro-fit, the pulley system may be easier to install. A very similar system is on John Doig's Piet. Photos at WestcoastPiet. Here's thetrim tab:http://www.westcoastpiet.com/images/WCP ... 574.JPGAnd the cockpit controls:http://www.westcoastpiet.com/images/WCP ... 98.JPGRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Jeff, I just use my trim to relieve stick pressures during level flight. The stick pressureschange a lot in my plane during fuel burn. I have a 10 gallon nose tankand a 12.5 gallon center section tank. When the nose tank only has 5 gallonsor lees in it I am very tail heavy. This is when I need the trim the most.Your question regarding trimming during landing is a definite no. I tend tonot make approaches in a straight line. I will usually be in a turning slipto final much like you see people do in a Pitts or other Biplanes. I don't evennotice the stick forces during landing. Oh, It's nice to have during climbout too. Not sure if that really answers your question, The plane isn't stable enough toever let go of the stick anyway.Cheers,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: "namrednos"
2nd BFR in my Piet. Word of advice: Make sure your CFI knows that you areflipping ON the smoke switch.Gary BootheNX308MB________________________________________________________________________________Subject: Pietenpol-List: Re: advice on trim mechanism
Wonder what the eye bolt on the top of the tail is for???Jack TextorWest Des Moines, IA-----Original Message-----
RE: Pietenpol-List: Request for Latex Paint Projects
I know this is a little off post, but this is a flight simulator our EAA Chapter just finished. This pic is in my shop and was before the decals were applied. We used Sherwin Williams latex primer and finish paint. We also used a short knap roller so we could get a flat =9Cmilitary=9D look. Found that if you =9Cgo over=9D the wet paint a second time, it creates a very flat look. See the windshield in the picture, it has a fuzzy look, but for our application, that=99s great. So apply one coat and let it get dry before applying another one if you want a glossy finish.This was our first attempt at latex, but after it turned out so good, I don=99t think it will be our last.BarryNX973BP
Photos, please. Thanks!--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: advice on trim mechanism
Jeff;This is a very interesting development. By all means, keep fiddling with it tosee if it can be made handier to use. I know I would be interested in it, because(for example) when I fly with the tank topped off (16 gallons in the nose),I have to hold back stick for the first hour or so till fuel burns off. Itwould be handy to trim for a more neutral stick, regardless of whether or notit was handy enough to use for trimming for approach.I think 55-57 is the sweet spot for approach speed in smooth air in most Piets,but 2 or 3 MPH either side of that can make a pretty significant difference inhow the approach goes. It's good to see the number that works for your Land-O-Maticapproach.Last thing: watch out for the Hun when you're vulnerable like you were on thatapproach (sun in your eyes). He'll come down right at you from high overheadwith guns blazing and you won't see him till it's too late and you hear bulletszipping through the wood and fabric ;o)--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
> To: "pietenpol-list(at)matronics.com" > Subject: Pietenpol-List: Ray Allen electric trim servo> > I installed a Ray Allen servo in the elevator under an inspection cover. The actuator rod exists the bottom and controls an approximately 10=C3=A2=82=AC=C2=9D section of 1=C3=A2=82=AC=C2=9D extruded aluminum piano hinge.> > Works great, lightweight, simple, unobtrusive and there=C3=A2=82=AC=84=A2s just a hidden switch in the cockpit.> > Douwe> > > > > This e-mail message (including any attachments) is for the sole use of> the intended recipient(s) and may contain confidential and privileged> information. If the reader of this message is not the intended> recipient, you are hereby notified that any dissemination, distribution> or copying of this message (including any attachments) is strictly> prohibited.> > If you have received this message in error, please contact> the sender by reply e-mail message and destroy all copies of the> original message (including attachments).> ky=C2=B7=C3=A8=C5=BE=C3=9B"=C3=8D=C3=AD=C5=93=C2=A2Z+=C3=93M4=C3=93G=C3=9Aq=C3=A7(=C2=BA=C2=B8=C5=BE=C2=AEw=C2=B0r=B9=C2=AB=B0=C3=C3=93=C3=A3=C3=A2z=C3=97=C2=A7=C2=B0K=C5-=C3=8BD=84=A2=C2=A8=C2=A5=16=C5-=C3=AE=84=A2K=1E=C2=B6=17=C5=92j=C3=9A=C3=A8=C5=BE',.+-=15=C3=C2=AD=C2=BA=C2=B7=C2=AC5=C2=AB=C3=A2=C2=81=C2=ABh=C2=AE=C3=9A=1B=C2=AE=C5=92,z=C3=98^=84=A2=C2=A9=C3=B2.+-=C2=BA=C3=98=C2=A5=C5-=C3=98=C5=BE=C2=B2=C3=8B=C5=93=C2=AB=0B=C5-=C3=8BT=C5=B8=C3=B4=C2=AEn=C3=87+=C5-=BAb=C2=A2p+r=18=C2=AFy'=C5=A1=C2=AD=C3=88C=C2=A3 =C3=A5=C2=A1=C2=A7{ =C2=AC=C2=81=C2=AE=C5=92,x(Z=C2=B4P=10>=1A-=C2=A2=C3=88Z=C2=AD=C3=C2=A7vk=C5=93-k=C5=93-j+y=C2=A8ky=C3=B8m=C2=B6=C5=B8=C3=C3=83=0C&j=C3=9A=C3=A8=C5=BE',r=B0=C25=C2=AB=C3=A2=C2=81=C2=ABh=C2=AC=C3=B8=C5=BE=C2=B5=C3=A9=C3=A9=C2=A2R=C3=A2=C2=B2=C3=98m=C2=B6=C5=B8=C3=C3=83=0C&j=C3=9A=C3=A8=C5=BE',r=B0=C25=C2=AB=C3=A2=C2=81=C2=ABh=C2=AC=C3=B8=C5=BE=C2=B5=C3=A9=C3=A9=C2=A2R=C3=A2=C2=B2=C3=9F=C3=9A0=04=C3=918=C3=92=02Ia=01=14=C3=A4T1$=C5=A1=84=A2=C3=A8+y=C2=AB=C2=A2{^=C5=BE=C3'=C2=A5=C2=B2-=C2=AFj)ZnW=C2=AF=B0=C2=ABayg=BA=16=C5-=C3=AE=C5=A1=C3=86=C2=A1=C2=AD=C3=A7=C3=A1=C2=B6=C3=9A=7F=C3=BD=C3=BA+=C2=BAk&j=C3=9A=C3=A8=C5=BE',r=B0=C2=A1=C2=B6=C3=9A=7F=C3=BD=C3=BA+=C2=BAk&j=C3=9A=C3=A8=C5=BE',r=B0=C2h=C2=B8=C2=AC=C2=B4*'=C2=B6=C2=B8=BA=C2=BA=C3=98=C2=A8=C2=9Dg=BAJ+^N=16=C2=A7=9C*.~=C5-=C3=B2=C2=A2=C3=C3-zw=C2=AB=C2=A2=C3=AB,=C2=BA=C5=A1h=C2=AE=C3=93=1A=C2=B6=C3=90=C3=ABjY^.+-=01=C3=99=C2=A2=C2=9D=C2=A8ky=C3=B8m=C2=B6=C5=B8=C3=C3=83=0C&j=C3=9A=C3=A8=C5=BE',r=B0=C2r=B0=C3=AD=C2=AE&=C3=AE=C2=B6*'-=C3=9Bi=C3=C3=BC0=C3=82f=C2=AD=C2=AE=B0=C3=A2r=C3=87(=BA=C3=B7(=C5=BE=C3=9A=C3=A2n=C3=ABb=C2=A2=7F=C3=9A=C3=BD=C2=C3=9F=C2=A2{=7F=C2=C2=B7=C2n=A1r=C3=BE=1Bf________________________________________________________________________________Subject: Pietenpol-List: Re: advice on trim mechanism
