Pietenpol-List: Wavy Okoume Plywood Leading Edge
Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeled with ribs, compression struts and leading edge glued). I used cargo straps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunken or wavy between several of the ribs (picture). The other wing seems OK with a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through the fabric (not having covered an airplane before). I want to remove it and try over. Any ideas of what went wrong? Any ideas on how to remove it?Tim WhiteOcklawaha, Fl________________________________________________________________________________
RE: Pietenpol-List: Wavy Okoume Plywood Leading Edge
Original Posted By: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim White
Tim,Were the cargo straps directly on top of the ribs? If so, I don't think they couldhave caused the deformation. You said you glued them two weeks ago andthen moved them to Florida. How long have they been in Florida? I suspect thatFlorida is the culprit. Being very humid, the Florida air will make the plywoodswell and deform between the ribs. Can you move the wing(s) into a heatedspace and let them acclimate for a couple of weeks? If so, I expect you'llfind that they smooth right out.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Original Posted By:> aa5flyer(at)gmail.com
How to remove it: Heat the plywood surface over a glue joint with a hot iron. The joint will separate like peeling a post-it note.Lorenzo> To: pietenpol-list(at)matronics.com
Toe-in is BAD for a tailwheel airplane. Imagine this, While on the runway youloose directional control. The plane heads off to the right, the left wheel willbe carrying the majority of the loads. If that wheel is "Toed-in" it willhave the tendency to tuck in under the plane. Another words, it will want toturn right. Hold your hands out in front of you, on a vertical plane. These are your wheels,Toe your hands in, Now turn right with both hands. You will see that the outsidehand will want to turn tighter since it is aimed at a different directionthen the forward direction of the fuselage. The best adjustment will be to have both wheels pointed straight ahead. Zero toe-inor toe-out. The trick is to get the wheels straight while the plane is inthe 3pt attitude and while in the level position. This is why a straight axle arrangement works so well.Happy landings,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 4 Nov 2015 07:18:43 -0800
Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
Original Posted By: goffelectric(at)comcast.net
Tim when I did mine, same conditions, temp, humidity, etc, I had one turn out perfectand the other with a dip in each bay. Hoping the fabric pulls it down...Sent from my iPadJack Textor> On Nov 4, 2015, at 7:53 AM, Tim White wrote:> > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeledwith ribs, compression struts and leading edge glued). I used cargo strapsaround each rib and clamps on the font edge to secure it while curing. Broughtthe wing to Florida for the winter and found the plywood was sunken or wavybetween several of the ribs (picture). The other wing seems OK with a slightbulge on the plywood away from the leading edge. I am at a loss to determinehow this happened unless I got the cargo straps too tight. I assume this deformationwill transmit through the fabric (not having covered an airplane before).I want to remove it and try over. Any ideas of what went wrong? Any ideason how to remove it?> > Tim White> Ocklawaha, Fl> ________________________________________________________________________________Date: Wed, 4 Nov 2015 17:33:07 +0000 (UTC)
Original Posted By: David
Tim just an idea... If you have not varnished yet, wet the underside of one baywith a cloth and see how it dries. Maybe heat with an iron???Sent from my iPadJack Textor> On Nov 4, 2015, at 7:53 AM, Tim White wrote:> > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeledwith ribs, compression struts and leading edge glued). I used cargo strapsaround each rib and clamps on the font edge to secure it while curing. Broughtthe wing to Florida for the winter and found the plywood was sunken or wavybetween several of the ribs (picture). The other wing seems OK with a slightbulge on the plywood away from the leading edge. I am at a loss to determinehow this happened unless I got the cargo straps too tight. I assume this deformationwill transmit through the fabric (not having covered an airplane before).I want to remove it and try over. Any ideas of what went wrong? Any ideason how to remove it?> > Tim White> Ocklawaha, Fl> ________________________________________________________________________________
Re: Pietenpol-List: Is this meant to be a Piet?
http://www.cnn.com/2015/10/22/africa/as ... insiteThis is the plane that Asmelash Zeferu will attempt to take off in -- despite having never flown before. The Ethiopian researched for over 10 years before spending 570 days building the plane, modeled on one used to train pilots in the U.S. during the 1920s and 30s.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________________________________________________________________________________Date: Wed, 4 Nov 2015 15:29:48 -0600Subject: Re: Pietenpol-List: Is this meant to be a Piet?
Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
A GN-1...obviously the town stud...Sent from my iPadJack Textor> On Nov 4, 2015, at 3:29 PM, Steven Dortch wrote:> > Built to plans. Heck I may try the exhaust shield.>> On Nov 4, 2015 2:20 PM, "David" wrote:>> http://www.cnn.com/2015/10/22/africa/as ... f=obinsite>> >> ________________________________________________________________________________Date: Wed, 4 Nov 2015 19:55:23 -0200Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
RE: Pietenpol-List: Is this meant to be a Piet?
He might save some weight by taking the sprockets off the motorcycle wheels.
Pietenpol-List: Re: Is this meant to be a Piet?
Original Posted By: Jack
He could be one of us on this list. He obviously has access to a computer to watchyoutube. Makes a guy want to go down there and help they poor fella out. We could takeup a collection and at least send him a suitable engine. On second thought, hewon't get too hurt with only a VDub engine. It's safer for him that way. Gives a new meaning to "Your results may vary"--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: Finally on the Gear!
Charles I used brads on mine...Sent from my iPhone> On Nov 4, 2015, at 3:55 PM, "Charles N. Campbell" wrote:> > Next time make sure the cargo straps are on a rib location. C> >> On Wed, Nov 4, 2015 at 11:53 AM, Tim White wrote:>> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeled with ribs, compression struts and leading edge glued). I used cargo straps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunken or wavy between several of the ribs (picture). The other wing seems OK with a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through the fabric (not having covered an airplane before). I want to remove it and try over. Any ideas of what went wrong? Any ideas on how to remove it?>> >> Tim White>> Ocklawaha, Fl> ________________________________________________________________________________Subject: Pietenpol-List: Re: Finally on the Gear!
Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Original Posted By: "tools"
Here's a link to a previous discussion on toe-in/toe-out. At the end there's anarticle from the old SAA magazine "To Fly."http://forums.matronics.com/viewtopic.p ... =toeinBill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Original Posted By: Semih Oksay
Looks like the plywood swelled. If heating removes it successfully, might layback down alright.Maybe get the wing somewhere air conditioned and see if the problem corrects itself.Then varnish it. Under tension, should be alright, as in if it moves to a condition of less humidity.Aluminum skins can do the same thing if installed cold, and then put in the sun.Recommend varnishing as soon as practical after installation to help stabilizethe wood with respect to moisture content.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By:> ** owner-pietenpol-list-server(at)matronics.com [mailto:
Subject: Re: Pietenpol-List: Is this meant to be a Piet?Looks ok compared to some homebuilts. I would check cg very carefully=8B andthe power plant? Obviously a Piet inspired project. Can we reach and warnhim about at least cg if all else is fine?Semih2015-11-05 0:04 GMT+02:00 The real bike Mike :> He might save some weight by taking the sprockets off the motorcycle> wheels.>>
Re: Pietenpol-List: Re: Finally on the Gear!
Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading EdgeI looked at the photo carefully. The plywood was glued correctly. This isnot a cargo strap location error. It seems like moisture problem. I havebeen to Florida and know about the humidity. Heating is a solution but I donot recommend local heating with a gun. A few days in a dry room shouldmake it fine. If you have a problem about drying the room, please contactme. In addition, never varnish one side of a thin plywood or veneer andforget it. It curves towards the varnished side because one day moistureswells the unvarnished side.my 2=8B centsHappy landingsSemih2015-11-05 1:05 GMT+02:00 Jack :> Charles I used brads on mine...>> Sent from my iPhone>> On Nov 4, 2015, at 3:55 PM, "Charles N. Campbell" charlescampbell1924(at)gmail.com> wrote:>> Next time make sure the cargo straps are on a rib location. C>> On Wed, Nov 4, 2015 at 11:53 AM, Tim White wrote:>>> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge>> (trammeled with ribs, compression struts and leading edge glued). I used>> cargo straps around each rib and clamps on the font edge to secure it while>> curing. Brought the wing to Florida for the winter and found the plywood>> was sunken or wavy between several of the ribs (picture). The other wing>> seems OK with a slight bulge on the plywood away from the leading edge. I>> am at a loss to determine how this happened unless I got the cargo straps>> too tight. I assume this deformation will transmit through the fabric (not>> having covered an airplane before). I want to remove it and try over. Any>> ideas of what went wrong? Any ideas on how to remove it?>>>> Tim White>> Ocklawaha, Fl>>>>-- Semih Oksay________________________________________________________________________________Subject: Re: Pietenpol-List: Re: Finally on the Gear!
Original Posted By: Tim White
Bill thanks once again for your thoughtful info...Sent from my iPadJack Textor> On Nov 4, 2015, at 8:52 PM, "Bill Church" wrote:> > > Here's a link to a previous discussion on toe-in/toe-out. At the end there'san article from the old SAA magazine "To Fly."> http://forums.matronics.com/viewtopic.p ... ight=toein> > Bill C.> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 747#448747> > > > > > > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
they wereOn 11/4/2015 4:55 PM, Charles N. Campbell wrote:> Next time make sure the cargo straps are on a rib location. C>> On Wed, Nov 4, 2015 at 11:53 AM, Tim White > wrote:>> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading> edge (trammeled with ribs, compression struts and leading edge> glued). I used cargo straps around each rib and clamps on the> font edge to secure it while curing. Brought the wing to Florida> for the winter and found the plywood was sunken or wavy between> several of the ribs (picture). The other wing seems OK with a> slight bulge on the plywood away from the leading edge. I am at a> loss to determine how this happened unless I got the cargo straps> too tight. I assume this deformation will transmit through the> fabric (not having covered an airplane before). I want to remove> it and try over. Any ideas of what went wrong? Any ideas on how> to remove it?>> Tim White> Ocklawaha, Fl>>________________________________________________________________________________Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
Original Posted By:> owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim White
Jack,It is 90 degrees with up to 100% humidity (some places setting records). I was very careful to put the straps directly on the ribs. I'm going back to Ohio for the holidays, think I'll let them sit until the heat and humidity go down in January. Thanks much for your help.TimOn 11/4/2015 9:17 AM, Jack Philips wrote:>> Tim,>> Were the cargo straps directly on top of the ribs? If so, I don't think theycould have caused the deformation. You said you glued them two weeks ago andthen moved them to Florida. How long have they been in Florida? I suspectthat Florida is the culprit. Being very humid, the Florida air will make theplywood swell and deform between the ribs. Can you move the wing(s) into a heatedspace and let them acclimate for a couple of weeks? If so, I expect you'llfind that they smooth right out.>> Jack Phillips> NX899JP> Smith Mountain Lake, Virginia>> -----Original Message-----
Original Posted By:> > aa5flyer(at)gmail.com
Lorenzo,Thanks for the tip. I'm going to let it sit for a while until the heat and humidity goes down and see what happens. Might still have to take it off.TimOn 11/4/2015 9:20 AM, larharris2 Harris wrote:> How to remove it: Heat the plywood surface over a glue joint with a > hot iron. The joint will separate like peeling a post-it note.>> Lorenzo>>> > To: pietenpol-list(at)matronics.com
Think I'm going to wait until the heat and humidity goes down. Meanwhile, I'll work on the center section. Thanks to all who replied.Tim WhiteOn 11/5/2015 2:09 AM, Semih Oksay wrote:> I looked at the photo carefully. The plywood was glued correctly. This > is not a cargo strap location error. It seems like moisture problem. I > have been to Florida and know about the humidity. Heating is a > solution but I do not recommend local heating with a gun. A few days > in a dry room should make it fine. If you have a problem about drying > the room, please contact me. In addition, never varnish one side of a > thin plywood or veneer and forget it. It curves towards the varnished > side because one day moisture swells the unvarnished side.>> my 2 cents>> Happy landings>> Semih>> 2015-11-05 1:05 GMT+02:00 Jack >:>> Charles I used brads on mine...>> Sent from my iPhone>> On Nov 4, 2015, at 3:55 PM, "Charles N. Campbell"> > wrote:>>> Next time make sure the cargo straps are on a rib location. C>>>> On Wed, Nov 4, 2015 at 11:53 AM, Tim White > > wrote:>>>> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my>> leading edge (trammeled with ribs, compression struts and>> leading edge glued). I used cargo straps around each rib and>> clamps on the font edge to secure it while curing. Brought>> the wing to Florida for the winter and found the plywood was>> sunken or wavy between several of the ribs (picture). The>> other wing seems OK with a slight bulge on the plywood away>> from the leading edge. I am at a loss to determine how this>> happened unless I got the cargo straps too tight. I assume>> this deformation will transmit through the fabric (not having>> covered an airplane before). I want to remove it and try>> over. Any ideas of what went wrong? Any ideas on how to>> remove it?>>>> Tim White>> Ocklawaha, Fl>>>>>>> -- > Semih Oksay________________________________________________________________________________Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
Original Posted By:>> owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-l
Does this mean that you may fly only in hot, dry areas? Maybe the leading edges should be installed only during maximum humidity conditions? I live in hot, dry California where I installed my leading edges. What will happen if I fly back to Brodhead? Assuming, of course, that I would/could do such a thing?Ray KrauseSent from my iPad> On Nov 5, 2015, at 4:07 AM, Tim White wrote:> > > Jack,> > It is 90 degrees with up to 100% humidity (some places setting records). I was very careful to put the straps directly on the ribs. I'm going back to Ohio for the holidays, think I'll let them sit until the heat and humidity go down in January. Thanks much for your help.> > Tim> >> On 11/4/2015 9:17 AM, Jack Philips wrote:s.com>>> >> Tim,>> >> Were the cargo straps directly on top of the ribs? If so, I don't think they could have caused the deformation. You said you glued them two weeks ago and then moved them to Florida. How long have they been in Florida? I suspect that Florida is the culprit. Being very humid, the Florida air will make the plywood swell and deform between the ribs. Can you move the wing(s) into a heated space and let them acclimate for a couple of weeks? If so, I expect you'll find that they smooth right out.>> >> Jack Phillips>> NX899JP>> Smith Mountain Lake, Virginia>> >> -----Original Message-----
Original Posted By: "wheelharp"
I can't imagine how difficult it would be to acquire quality building materialsand tools to build with there. It makes me appreciate even more everything Ihave access to here.That said, it looks like his left wing trailing edge is warped downwards prettybad...hopefully that gets corrected before he attempts flight again (which Ithink is this month?)--------Jon JonesIronton, MORead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Is this meant to be a Piet?
Here is difference in angle that I see.--------Jon JonesIronton, MORead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/angl ... ______Date: Thu, 5 Nov 2015 11:53:52 -0800
Is there a way to see if he is on this forum? Is it possible to get his email address?Come on, you computer geeks?Ray KrauseSent from my iPad> On Nov 5, 2015, at 9:25 AM, wheelharp wrote:> > > Here is difference in angle that I see.> > --------> Jon Jones> Ironton, MO> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 781#448781> > > > > Attachments: > > http://forums.matronics.com//files/angle_125.jpg> > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Re: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Original Posted By: "Andre B. Charvet"
WF2,Laminar flow? Really?On a Pietenpol wing?Wonder how 6-ply hard cardboard might fare.You know, as shown in the plans.I don't think the use of Okoume vs Aircraft ply is an issue here.BCRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 06 Nov 2015 07:19:11 -0500Subject: Re: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
WF2,In your wing pic, there are two aets of green structural items; one of which isclearly part of the wing itself. The other appears to be some form of wing stand...Would you care to show a few pics of the stand, and tell us how is works, etc.?Thanks!--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Is this meant to be a Piet?
This guy has great ambitions. I picked up the phone yesterday and called EAA tosee if they knew about this fella. I'm thinking that it would be a kind jesterto bring him to Osh next year so he can see how it should be done. Long storyshort, It was lunch time in Osh so I didn't get a chance to speak with anyone.If you look closely you can see all the nails or screws he use to attach the coveringmaterial to the longerons. I think at best this gentleman has somethinghe might be able to taxi around a little. There is not enough power there toeven get the tail off the ground. Nothing is straight and all the cables arejust kinda tied on with knots. I may try and call EAA again today if I get a chance. I think the best help wecan offer him is to mentor him for his next project.He has registration numbers on it so I'm sure EAA could find him that way. I don'tthink that CNN would give up the guys contact information to any of us commonfolk. Maybe to EAA, but not us.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
What plywood did you use? Source? Thickness?Tim WhiteOn 11/5/2015 3:54 PM, womenfly2 wrote:>> The lead edge is very critical to the airflow and must be have a very smoothtransition or you will not have an laminar airflow which could stall the wingat higher airspeed.>> Issue with not using aircraft grade plywood ... ? Did a plywood leading edgeon my Piper L-4, still smooth as when I applied it. See pictures on my link below.>> Remove and start over .... no covering will help it and if reworked with heat,will come back later with humidity changes. Apply new skins and seal right awayto stabilize the wood.>> Be safe!> WF2>> -------->>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 6 Nov 2015 12:55:14 -0200Subject: Re: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Original Posted By: "simmor2"
https://www.facebook.com/asmelash.zeferuRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Oscar/Steve,Thanks for the info. I really considered the Flybaby because of the leg room but,although I seldom have a passenger, I like having the extra seat just in case.And yes, the shade will be handy;)Thanks,BillRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
I used Finnish plywood of 1mm thick about 3/64" from Aircraft Spruce. Their P/N:02-50000My web site should work click on lnk below, but if not copy and paste in your browser:Your wing surface should be smooth as possible. Good luck.WF2--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
The world does not have a duty...Big time engineer named Octave sure helped a couple of quack brothers from someweird place in Oh-hi-yo a few years ago...Sent from an iPhone with a spelling problem> On Nov 7, 2015, at 8:08 PM, taildrags wrote:>>> People have dreamed of flying since the creation. This gentleman in Ethiopiais doing better than a lot have done, but the world does not have a duty to helpevery dreamer make every contraption safe any more than it has a responsibilityfor what the results of the experiment are. You can bore yourself watchingvintage videos of early attempts at flight, but here's a 7-minute sampling:>> https://www.youtube.com/watch?v=Sp7MHZY2ADI>> Some are entertaining, some are sad, a few are novel, a few were successful.The Ethiopian fellow's project is just one more in an almost timeless progressionof attempts to make wings and fly.>> --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ______This e-mail message (including any attachments) is for the sole use ofthe intended recipient(s) and may contain confidential and privilegedinformation. If the reader of this message is not the intendedrecipient, you are hereby notified that any dissemination, distributionor copying of this message (including any attachments) is strictlyprohibited.If you have received this message in error, please contactthe sender by reply e-mail message and destroy all copies of theoriginal message (including attachments).________________________________________________________________________________Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Bill Church wrote:> WF2,> > Laminar flow? Really?> On a Pietenpol wing?> > Wonder how 6-ply hard cardboard might fare.> You know, as shown in the plans.> > I don't think the use of Okoume vs Aircraft ply is an issue here.> > BCYes, really. All airfoils rely on laminar flow. That is different than a laminarflow airfoil, which is specifically designed to exploit laminar flow. The opposite of laminar flow is turbulent flow, as seen during boundary layer separation,which nearly defines a stall. Do the original plans call for gluing or nailing the leading edge skins? Nailingwould allow the skin to move with moisture content variation.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Okay, maybe I misread the original statement.Having a smooth transition between the leading edge and the plywood attached toit is important, since this is the only part of the wing that will experiencelaminar flow (probably not more than the first 6" or so of the Pietenpol airfoilwill experience laminar flow), and roughness or sharp edges would disruptthat.However, after the covering is applied, the fabric will pull down on the plywoodbetween the ribs, effectively changing the airfoil. But it's been that wayfor over 80 years, and seems to be working all right so far.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
It is wishful thinking that the plywood will pull down when the fabric is applied.Never seen that happen, what ever the structures is under the fabric it willbe that way when finished. Every aircraft manufacture will tell you the leadingedge needs to be smooth. In my experience I have no knowledge of it being like that for 80 years, not what I have seen.There is no excuse for not correcting the issues and making it right, deep downwe all what it to be right. Even dents on a Cubs leading edge can make the wingloose lift and needs to be corrected.Be helpful and truthful, all aircraft need to be built with the best skill andpractices possible. If its not right correct it, its your life up there and yourpassenger if you take one .... their entrusting you with their life.WF2--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Maybe there is some confusion by the question. Clearly, the plywood pullsdown between the ribs, even though it starts out as straight. It is saidthat it is preferred not to be supported by a filler on the spar, betweenthe ribs, to allow for it to be pulled down and make a smoother transition. I know for fact that my wing 'grows' during Winter, as I can see the aileronbutt gap get closer when the humidity rises for an extended time (CA). JackPhillips made the best suggestion, to allow it some time in a heatedenvironment, and see if the plywood straightens up...then varnish! Gary BootheNX308MB-----Original Message-----
On my Piet I used 45 degree mahogany plywood, I know its expensive, but I had noissues with it. It stayed pretty smooth in all temperature and humidity conditionshere in NH.One thing is to add some stringers on the leading edge as in a model plane to givethe plywood some support between the ribs too. Helps to keep the shape. ButI really do not see the need for them on a Piet, the sheet area is pretty shortand only on the top. If the wood is dried properly it should absorb very littlemoisture in the bare condition. Seal it as soon as its applied will helpstabilize it too .... sealing both sides at the same time helps.All good input,WF2--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Call it wishful thinking if you want. I prefer to call it observing details.If the plywood skin at the leading edge of the wing is installed per the plans(with no reinforcing at the back edge), the fabric will naturally pull the plywooddown between the ribs, in the same way that the fabric pulls down betweenthe ribs. This is not a drastic deflection, but it certainly is observable.In fact, the two photos supplied by Gary illustrate my point. The first photoshows the uncovered wing structure, with flat plywood. In the second photo,with the wing covered, the deflection of the plywood can be seen at the righthand side of the photo. For another example, see this photo:http://www.westcoastpiet.com/images/Jac ... _136.JPGIn this aircraft, with the airfoil that it has, the trailing edge of the plywoodin question is most likely no longer in the area of laminar flow.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Jack,He sounds very pleased to be making contact with us. I hope we can sincerely helphim in his quest. On his face page he has a lot of pictures of his build. Itall looks quite familiar!RaySent from my iPad> On Nov 9, 2015, at 11:36 AM, Jack wrote:> > > Ray in response to your note to Asmelash I signed him up for the Pietenpol pageand sent him a note with that info and the EAA site.> > Sent from my iPad> Jack Textor> >> On Nov 9, 2015, at 12:06 PM, Ray Krause wrote:>> >> >> Oscar and Jeff,>> >> I have made email contact with Asmelash Zeferu in Africa, thanks to Ryan' ssleuthing! I sent you a copy of my email to him giving him directions to jointhe PIETENPOL Forum. I hope that if he joins the Forum, our members will be helpfuland recognize the great effort he has gone through under very trying circumstances.I have lived in similar countries with like resources, so I recognizehis determination! We should be able to offer helpful encouragement.>> >> He says he has calculated the W/B. >> >> Thanks,>> >> Ray Krause>> >> Sent from my iPad>> >>> On Nov 8, 2015, at 10:02 PM, taildrags wrote:>>> >>> >>> Jeff (Boatright)- thank you for taking me down a notch. As a result of beingon this list I have low and slow aviation friends all over the world and Iam much the richer for it. My intention in making the statement that the worlddoes not owe me (or any other experimental aircraft builder) a duty to helpin our success does not mean that we shouldn't jump in and help when we can. It certainly does NOT mean that we shouldn't try, either. It just means thatsometimes we get individual ideas and visions in our heads and we push forwardwith them no matter what the world around us says. In those cases, we just haveto do what is in our hearts and heads to do, and failure is certainly an optionwhen we buck the trend and the best advice and just push forward anyway.In fact, sometimes our instinct tells us that something probably won't workbut we have to try it to see why it doesn't work and to see if we can find outhow we might be able to make it work. I know this i!> s!>> h!>>> ow "Aviken" feels with his Jeep engine Air Camper project, and how some ofthe rest of you feel with your personalized, "different", custom, unusual, orunorthodox approaches to things.>>> >>> I think that the Ethiopian chap did what he did, the way he did it, becausehe doesn't have a Wicks, or an Aircraft Spruce, or even a Lowe's or Home Depotor Harbor Freight, or an eBay, or Amazon, or Barnstormers, or a credit cardavailable to him. He has a dream and he put it together the best way he knewhow, with what he had available, in spite of what he DIDN'T have. We laugh whenwe watch the video and the prop flies off just after he fires up the engine,but deep inside we didn't want it to just end there. Maybe we would still havelaughed if a wheel fell off after he warmed it up and taxied out, or if anynumber of other awkward things would have happened later- but the video wouldhave gone absolutely viral if his rig would have made it to the runway, andhe throttled it up, and he stumbled and bumbled and bumped it down the runwayfar enough to where it came up onto the mains and got even a foot or two of airunder the tires for even just a few seconds before !> s!>> om!>>> ething else happened and it came crashing back to the ground. And granted,with as much questionable stuff as he had on it, there is no doubt that it wouldhave come down sooner rather than later.>>> >>> We would have cheered the fact that he flew it. We would have felt what hefelt, because we have felt it too. We would have welcomed him into the fraternityof aviators, because he earned it. And maybe he will.>>> >>> Far be it from me to deprive this man from any part of what he has put hisheart and soul to do, and to attempt. I hope he makes it.>>> >>> -------->>> Oscar Zuniga>>> Medford, OR>>> Air Camper NX41CC "Scout">>> A75 power>>> >>> >>> >>> >>> Read this topic online here:>>> >>> http://forums.matronics.com/viewtopic.p ... 007#449007> > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Don't the plans show 28 ga aluminum, which would eliminate any of the seasonalexpansion?--------Jon JonesIronton, MORead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Jon,No, the plans do not show 28ga aluminum. They call for the use of 6-ply hard cardboardor 1/16" plywood. Don't think anybody has used the cardboard optionfor many years, though.Some have used aluminum, but there are issues to contend with if you choose togo that route. One issue is figuring out how to attach the aluminum to the woodenribs. Glue will not work (in the long run), and nails will eventually worktheir way out. Another issue is that aluminum and wood will expand and contractat different rates, as the temperature rises and falls.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Scot and Ray I mentioned WestCoast Piet to him also...Sent from my iPadJack Textor> On Nov 10, 2015, at 11:51 AM, "AircamperN11MS" wrote:> > > Ray,> > Thanks for contacting him. I do not have facebook. It is great that he is offered this site as another resource to him. We need to also let him know about www.westcoastpiet.com as well. > > As others have said, if he reaches out to us, we should do everything we canto help him with his quest. > > Asmelash has great ambition and a great drive. He has proven that to me. WhenI look at the Youtube video, I can't help but wonder which of all those youngfaces in that group he is influencing????? I wonder who influenced him? I wonderif a plane from this group is what gave him inspiration? Maybe he had seenMike Cuy's, Gary Boothe's, Tools, or even my plane? Hard to say. But we allare the guys and gals who are keeping Bernie Pietenpol's dream alive. It lookslike it may be his turn in Africa to keep the dream alive. > > I hope to see him on this forum asking questions. > > Cheers all,> > --------> Scott Liefeld> Flying N11MS since March 1972> Steel Tube> C-85-12> Wire Wheels> Brodhead in 1996> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 129#449129> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Hmmm... I never noticed that before. The Flying and Glider plans actually dosay to use 28ga aluminum on the leading edge of the wing. I have no idea how anyone manages to actually build an airplane using only theplans in the Flying and Glider reprints. Those drawings are so small.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
In Des Moines IASent from my iPhone> On Nov 11, 2015, at 2:46 PM, Tony Crawford wrote:> > Hi,> Do you live anywhere near northern Alabama?> > Tony> >> On Wed, Nov 11, 2015 at 1:26 PM, Jack wrote:>> Tony here is what I found on drawing 4. I'm more perplexed because my existing post is 5 1/2" between the floor bolts. Not sure where I came up with that years ago...>> Jack>> >> >> >> >> >> Sent from my iPad>> Jack Textor> ________________________________________________________________________________Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
> > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge > (trammeled with ribs=2C compression struts and leading edge glued). I > used cargo straps around each rib and clamps on the font edge to secure > it while curing. Brought the wing to Florida for the winter and found > the plywood was sunken or wavy between several of the ribs (picture). > The other wing seems OK with a slight bulge on the plywood away from the> leading edge. I am at a loss to determine how this happened unless I > got the cargo straps too tight. I assume this deformation will transmit> through the fabric (not having covered an airplane before). I want to > remove it and try over. Any ideas of what went wrong? Any ideas on how> to remove it?> > Tim White> Ocklawaha=2C Fl ________________________________________________________________________________Subject: Pietenpol-List: Re: Finally on the Gear!
> >> > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge> > (trammeled with ribs, compression struts and leading edge glued). I> > used cargo straps around each rib and clamps on the font edge to secure> > it while curing. Brought the wing to Florida for the winter and found> > the plywood was sunken or wavy between several of the ribs (picture).> > The other wing seems OK with a slight bulge on the plywood away from > the> > leading edge. I am at a loss to determine how this happened unless I> > got the cargo straps too tight. I assume this deformation will transmit> > through the fabric (not having covered an airplane before). I want to> > remove it and try over. Any ideas of what went wrong? Any ideas on how> > to remove it?> >> > Tim White> > Ocklawaha, Fl________________________________________________________________________________Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
