Original Posted By: "John m. Greenlee"
I'm getting ready to glue my fuselage halves together, but I was wonderingabout the engine mounts. Do they have to be fitted on the fuselage beforethey're joined, or can they be attached after the fuselage is assembled? Theupper mounts probably could be attached any time, but the lower mounts havea flap that looks like it would interfere with the placement of the lowercross strut.________________________________________________________________________________
Pietenpol-List: Engine mount fittings
Original Posted By: Emelita W
I don't see any reason why you should not go ahead and join your fuselage=sides.I used a router to cut the ends off the lower cross strut (with plyfirewall in place) in order to mount lower mounts. In other words I cutslots through the firewall/lower cross strut to accomodate the inside low=ermotor mounts. Works fine.John________________________________________________________________________________
