Pietenpol-List: Entry
>>>>>>My personal opinion, the flop sure makes life easier.The false spar is how I did it. If I remember, cut off the aft portionof the ribs at the aft upright, save that part, install a spar &construct the flop with the portion of the ribs you cut off. Screw on apiano hinge & there you are.I did one other thing, I extended the flopone bay into the left wing. That allows me to stand upright along sidethe cockpit.Mike B ( Piet N687MB )I'm 6'2 and 150 lbs. What are the implicationsregardinggetting in and outof the seat below the wing? Is a cut out ormoveable wingarea advisable?KevinDown here inHoustonI raised the cabanes by 3 1/2 inches, but did notdo theflop. Thecentre section is built and I am reluctant to go muss withit. IsupposeI could cut every thing off aft the back beam and fit a falsesparandhinge. Any other suggestions?My personal opinion, the flop sure makes life easier.The false spar is how I did it. If I remember, cut off the aftportion ofthe ribs at the aft upright, save that part, install a spar construct theflop with the portion of the ribs you cut off. Screw on a piano hingethere you are.I did one other thing, I extended the flop one bay intothe leftwing. That allows me to stand upright along side the cockpit.Mike B ( Piet N687MB )________________________________________________________________________________
