Pietenpol-List: Piet related computer help
Like many of you, I like to make copies of subjects that pertain to my type of project a good example being the current discussion on Model A prop hubs, prop bolts,etc. When there are numerous responses to the original message and they become cumulative on the screen it becomes a bit overwhelming to print them out especially when the length of the headers also increases and it sure goes through ink in a hurry. Could one of our talented discussion group computer gurus please tell me if there is some way that I can eliminate the duplication and the headers when I make copies. Maybe this is pretty elementary but I don't have a kindergarten kid in the house to advise me. Any help would be appreciated. Who knows there just might be others on the list with the same question. ThanksDon Hicks ________________________________________________________________________________
Pietenpol-List: Re: Piet related computer help
Original Posted By: dotcom(at)emaster.net
Hi there--highlight what you want to print, click "control and C together". Go down and click your start button, click programs, accessories, word pad. (This applies to Windows). When word pad comes up, click "control and V together". What you want to print should come up on the word pad screen. Click the print button and voila, what you want with out extras. Once it is printed out, click edit, select all, then the delete key on your keyboard to clear the screen. Then hit minimize (the minus button in the top right corner) and your e mail screen will come back. Repeat the highlight, control c, control v, print, and delete as you want to. Good Luck!!________________________________________________________________________________
Don,I use the mouse to highlight the desired text, select EDIT from the menu bar, click on COPY.Then open a word doc labeled Piettips.doc, find the correct area (of the currently 30 pages). position the cursor with the mouse, select EDIT and click on PASTE.After it is in the word doc you can massage the structure as you wish.Easy,DG________________________________________________________________________________
DonWhat I do is probably slow but it gives me what I want,Open new message then open message rec, highlite what you want and save innew open message, do this to all of the same type messages, after I get itall done I send it to myself. then when it comes back I can put it inanother file, print or anything else. Like getting a digest.I do this with alot of URL's that come thru.I'm sure someone else will have a better way.GordonIHA#02----- Original Message -----________________________________________________________________________________
Works good with Lotus Word Pro also.Even better than what I was doing.ThanksGordon----- Original Message -----________________________________________________________________________________
Original Posted By: kyle ray
hey!! it works and it's easy----thnxJoeCZion, IllinoisPatcoolnet(at)aol.com wrote:> Hi there--highlight what you want to print, click "control and C together".> Go down and click your start button, click programs, accessories, word pad.> (This applies to Windows). When word pad comes up, click "control and V> together". What you want to print should come up on the word pad screen.> Click the print button and voila, what you want with out extras. Once it is> printed out, click edit, select all, then the delete key on your keyboard to> clear the screen. Then hit minimize (the minus button in the top right> corner) and your e mail screen will come back. Repeat the highlight, control> c, control v, print, and delete as you want to. Good Luck!!________________________________________________________________________________
Your very welcome. My sis taught me how (she has a 19 year old son who has had a computer in his class room since kindergarden). Learning this stuff is easy if you can put it in terms we computer challenged adults can understand. Enjoy! Pat________________________________________________________________________________
Who are you replying too?Please leave message in that you are answering too, It makes no since to us.GB----- Original Message -----________________________________________________________________________________
Pietenpol-List: Re: HOW TO UNSUBSCRIBE (Again, and again, and again)
Original Posted By: GREA738(at)aol.com
Please take me off your mailing list thank you________________________________________________________________________________
