Pietenpol-List: controls
hey guys... i feel like i've seen a few pictures of plane with pulleys just behindthe drivers seat... is this pretty normal ??i was playing with my controls today and came up with this...jeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/imag ... __________
Re: Pietenpol-List: controls
Subject: Re: Pietenpol-List: controls
RE: Pietenpol-List: controls
Looks good Jeff, I think I see two pulleys and I assume you will fit with acable guard. I'm doing the rudder cable routing now which can go manydifferent ways.JackDSM-----Original Message-----
Rick- same on mine. Lower pulley barely moves.Dan HelsperPuryear, TN-----Original Message-----
Pietenpol-List: Re: controls
Original Posted By: "K5YAC"
all but the two behind the seat are 2 inch... the ones behind the seat are 3 inches...just because had them aroundworkin on the rudder bar today.. tryin not to bleed on stuff too much. i hate whenthe drill press grabsjeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: controls
Original Posted By: "bender"
I'm trying to understand what is going on here (see photo)... I can see that thereis a deflection because the line doesn't remain straight, and I understandthat you are pointing out that there is limited friction involved with the bottomcable, but is this cable routed below the fuse cross member or is there somekind of rub block mounted to the other side of the pulley? I know that itmust be contacting something, just not sure how you are doing this.--------Mark ChouinardWings, Center Section and Empannage framed up - Working on FuselageRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/cabl ... ___Subject: Pietenpol-List: Re: controls
the elevator cables from the rear control stick torque to the bellcrank won't clearthe bottom seat crossmember so i added those two pulley to keep the cablesoff of that crossmember..quite a deflection from the upper cable.... not somuch from the lowerjeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: controls
Pietenpol-List: Re: Sterling's Piet project for sale in Texas
Original Posted By: "Ozarkflyer"
Mark,If you look closely, you'll see that there are two pulleys there, side by side.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Sterling's Piet project for sale in Texas
Email address please.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Subject: Re: Pietenpol-List: DoneWow Dave,She's beautiful and what a work of art, if she fly's half as good as she looks you be stuck suffering from that menacing problem the that afflicts only a select few of the airplane builders in the county, "perpetual smile disorder".Best of luck and enjoy!JohnIn a message dated 5/9/2011 8:28:44 P.M. Eastern Daylight Time, dsornbor(at)aol.com writes:--> Pietenpol-List message posted by: "Dangerous Dave" Howdy,she's done.Will be inspected on the 17th and in the air shortly therafter.Highspeed taxi tests have been great,runs like a top.Can't wait!dave--------taking to hangarRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/2011 ... ___Subject: Pietenpol-List: Re: controls
Alright, that makes more sense. Where is the "like" button? Bill Church wrote:> Mark,> > If you look closely, you'll see that there are two pulleys there, side by side.> > Bill C.--------Mark ChouinardWings, Center Section and Empannage framed up - Working on FuselageRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 10 May 2011 14:30:35 -0500
Original Posted By: Jim Courtney
> --> Pietenpol-List message posted> by: "Jack" > > Looks good Jeff, I think I see two pulleys and I assume you> will fit with a> cable guard. I'm doing the rudder cable routing now> which can go many> different ways.> Jack> DSM> > -----Original Message-----
