Pietenpol-List: What are ya using to log your build?
Subject: Pietenpol-List: What are ya using to log your build?
RE: Pietenpol-List: What are ya using to log your build?
Been using www.mykitplane.com. No complaints..Gary
Re: Pietenpol-List: Re: What are ya using to log your build?
Subject: Re: Pietenpol-List: Re: What are ya using to log your build?
Re: Pietenpol-List: What are ya using to log your build?
Subject: Re: Pietenpol-List: What are ya using to log your build?
Original Posted By: "Matt Dralle"
Since Rapture didn't come, I have to do spring cleaning! Note the rolling wing stand.you can order those on my web site,www.rollingwingstands.com, or, if you want to build your own, you can getthe plans at: www.helpbuildingrollingwingstands.com. ;-)Hope everyone's having as good a day as I,Gary________________________________________________________________________________Subject: Pietenpol-List: Re: What are ya using to log your build?
mark.rbrts1(at)gmail.com wrote:> What are you using to document your build? I know there are websites, but I forgetwhich they are, and if they are better than starting your own. > > I want to document the build on line to share ideas and the build, and hopefullyencourage others as I was encouraged whilst on the sidelines.> Hi Mark,You should check out Kitlog Pro: It allows you to fully document your Experimental build including narratives, hours,pictures, vendors, receipts, everything. All of your data is stored ina local database file on your PC for safe keeping.Additionally, Kitlog provides a lifetime free service that allows you to uploadyour project progress to a personal website. You can upload each time you locallyadd a log entry or once a month. What ever you like. You can browse themany projects currently on Kitlog here: I documented the complete build of my Van's RV-8 using Kitlog and can't imaginedoing it any other way. Here is a link to my RV-8 website provided courtesyof Kitlog's service: The FAA inspector loved my documentation for my inspection. Family and friendsliked being able to keep up to date on my progress, too.Its the best $49 you'll spend on your project.Matt DralleRV-8 N998RV--------Matt DralleMatronics Email List AdministratorRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/matt ... ______Date: Sun, 22 May 2011 11:26:40 -0700
Pietenpol-List: Re: Nuthin ever works out like I plan...
Original Posted By: Woodflier(at)aol.com
Gary,I could not get either link to open up. Are the websites active? I would like tolook at them.--------Semper Fi,TerryRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: "K5YAC"
Yes, please.--------Semper Fi,TerryRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: What are ya using to log your build?
Perhaps Matt's airspeed indicator isn't properly calibrated yet? Or if his ASIis indicating correctly, he could throttle back a bit and get a little bit bettergph on the trip...--------Billy McCaskillUrbana, ILtail section almost done, starting on ribs soonRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 22 May 2011 19:17:15 -0700Subject: Re: Pietenpol-List: Re: What are ya using to log your build?
Ipod? Droid? Try a Russian Space Pen and this;http://www.43folders.com/2004/09/03/int ... er-pdaClif ----- Original Message -----
Original Posted By: "bubbleboy"
Matt I watched your video and man does it ever climb good. Looks to be a lot morethan 65 HP. Congratulations--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: What are ya using to log your build?
Hi Douwe - When I go on my extended "vacations" I use the plastic shrink wrap stuffthat movers use. You can get it at the u-haul store.--------Kevin "Axel" PurteeNX899KPAustin/Georgetown, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: What are ya using to log your build?
My purpose for keeping a detailed log is more than just the proof of builder, butmy 6 year old (4 years old when we started - maybe 10 or more before we finish),will have a detailed illustration of how we built our airplane. He is oldenough now to understand a little about how this is going together, and hasseen all of the assemblies take shape from sticks, but may not understand whywe did certain things. Anyhow, I hope this will be his airplane one day (wishfulthinking), and he may like to refer to the log.--------Mark ChouinardWings, Center Section and Empannage framed up - Working on FuselageRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
> *To: *pietenpol-list> *ReplyTo: * pietenpol-list(at)matronics.com> *Subject: *Pietenpol-List: 1" or 7/8">> Hi All:>> Can anyone verify a memory I have. I seem to rem= ember that in later> builds, Bernard used 7/8" stringers on the main 4 = fuse stringers...>> Is that correct, or is my memory= failing me already?>> Thanks for-the-feedback.>> M= ark>> *>=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D> *>>________________________________________________________________________________Date: Mon, 23 May 2011 21:07:14 -0700Subject: Re: Pietenpol-List: What are ya using to log your build?
