Pietenpol-List: Gusset Dimension
Original Posted By: "Piet2112"
ok, yes, it was an after thought! the corners had already been cut when i decided to add the other pieces!--------Earl BrownI may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Gusset Dimension
I've been searching the archives to find the dimensions of the aft fuselage gussetwithout any luck. Am I missing something in the plans?Curt MerdanFlower Mound, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/aft_ ... __________
Re: Pietenpol-List: Gusset Dimension
I measured the 18-inch dimension from the plans as 1.5 inches. Top dim of gusset = .25 and bottom = .5. 18/1.5 = top/.25 = 3 inches. Bottom is twice that or 6 inches.----- Original Message -----
