Pietenpol-List: Piet friendly intercom systems
Original Posted By: "tools"
Sometimes... no, A LOT of times it is necessary to have bends that are across thegrain and also with the grain. When bends are made parallel to the grain, alarger radius needs to be used to avoid over-stressing the metal (cracking).That's life.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Piet friendly intercom systems
Original Posted By: cutlertxs(at)comcast.net
Having a difficult time with comms in the Piet. Is there a simple PTT intercomsystem available? They all seem to be VOX only until you get to the five hundredbuck range. Would also like independently adjustable volume.Thanks,ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 25 Oct 2011 02:28:54 +0000 (UTC)
Pietenpol-List: Re: Bending 5052 Fuel Tank
Hay Jack have you made inspection holes through the top like Gary to get the sealantin?Gary are those covers screwed on and how have you sealed underneath?I think I am going to start again and rivet the tankThanks CarsonRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: Bending 5052 Fuel Tank
Carson,I first made 'backer plates' to receive sheet metal screws, but the coversare sealed and held in place with the screws. Inner tank repairs willrequire screw removal, then working the covers loose from thesealant...sorta like on a Mooney.Gary -----Original Message-----
Thanks GaryOne more question did you make the backer plates thick enough so the screws didnot go all the way through?carsonRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Backer plates are only .040. Screws are set in sealant, too.-----Original Message-----
