Pietenpol-List: Aileron cable quick disconnect
Used T-88 with No: 8 Sheet Metal screws into nose web of rib, with drilled hole.T-88 is strong alone, reason I used screws was to fixture Leading-edge in placeand acting as a clamp until T-88 cured.--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 28 Nov 2011 08:02:04 -0600Subject: Pietenpol-List: Aileron cable quick disconnect
RE: Pietenpol-List: Aileron cable quick disconnect
I just used turnbuckles and shackles in the wings. Pain in the butt todisconnect and connect, but not something you do every day, and certainlybetter than cutting the cables.Jack PhillipsNX899JPSmith Mountain Lake, Virginia _____
Darn, forgot to attach the picture.I just used turnbuckles and shackles, as shown in the picture below:If you look to the left and right of the centersection, you can see theaileron cables and the turnbuckles and shackles. These are accessiblethrough inspection ports on the bottom of the wings. I also used quickdisconnect fittings for the pitot and static lines, made by Colder Products.http://www.colder.com/Tabid/72/Material ... s.aspxJack PhillipsNX899JPSmith Mountain Lake, Virginia _____
Re: Pietenpol-List: Aileron cable quick disconnect
Subject: Re: Pietenpol-List: Aileron cable quick disconnect
Pietenpol-List: Re: Aileron cable quick disconnect
Original Posted By: "Jason Holmes"
I made sets of plates like the connecting link on a bicycle chain. used 3/16" diameterclevis pins and cotter pins through them. actually went to the troubleof drilling out 1/4" stainless tubing and cutting short sleeves to eliminateany wear on the pins and they were long enough to keep the side plates from beingtight against the cable thimbles.I made them to a length that allowed me toeliminate the turnbuckle on the upper aileron cable- after crimping the nico's/that way I got it close enough to hold them level with the trailing edgesof the wings.didn't save much weight but I am a tightwad. RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Pietenpol Mid Air
I just remembered reading a news story somewhere that the FAA has areporting website for bird strikes as they are trying to gather data. Itis: http://wildlife-mitigation.tc.faa.gov/w ... --Original Message-----
Re: Pietenpol-List: Re: Aileron cable quick disconnect
Glad you were not hurt. A bird strike is one scary event.Took a bird through the front canopy of a T-34C one night at about 9500' AGL about100 miles North of Corpus Christi, TX. It sounded like a shotgun went offover my head. we got down okay and landed with a huge hole right in front of myface (the student was under the hood in the back seat doing an instrument hop).When the student asked me why the bird was out flying at night, I told himthat I guess the bird was out getting his night minimums. :0)--------Semper Fi,Terry HandRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 28 Nov 2011 22:36:01 -0600Subject: Re: Pietenpol-List: Re: Aileron cable quick disconnect
Re: Pietenpol-List: Hi I'm new here.
Hi I am Matthijs de Groot from Holland (Texel)I got the Drawings in march this year.So far I have build the ribs and the tail section.Im planning to do the metal work this winter and start on the Ford A motor I found pumping water at a farm in Holland.Im hoping to find someone that has CAD Drawings of all the metal fittings so I can have them cut by a friend here in Holland. I found a Dutch company selling the 4130 steel.For the rebuilding of my motor im looking for a( garage hand book)whit all the tolerances so I can find out what is good and bad in my engine so I can start making it like new.I found a Bendix S4LN type nr 10-51-360-37 Magneto I can buy for 450,- is this a good option?So 1 cad drawings metal fittings 2 detailed motor info ford A 1928 3 any info on magnetos(should I buy or look further).________________________________________________________________________________Subject: Re: Pietenpol-List: Hi I'm new here.
Original Posted By: Matthijs de Groot
Hi Matthijs,Welcome to the Piet list. There are others on this list who have already forged the road of the CAD drawings for all the steel parts. Hopefully one of them can pipe up and let you know how to proceed. A good resource for manuals on the Ford is Snyder's Antique Auto. http://www.snydersantiqueauto.com/Remember, there is a wealth of knowledge if you search the Piet List archives.Good luck,Dan HelsperPuryear, TN-----Original Message-----
Welkom Matthijs,Nice to see another Pietenpol in Holland Vroege Vogels in Lelystad has one in their collection. http://earlybirdsmuseum.nl/en/pietenpol-aircamperAnd their is one being build in Hoogeveen http://www.dutchnostalgicwings.nl/You can substitute 4130 with DIN 1.7218 steel, same composition but to a German standard.And perhaps easier to obtain in EuropeHave Fun Building and Flying.Hans van der VoortNX15KVWaller, TX-----Original Message-----
