Original Posted By: Ken Chambers
Subject: Pietenpol-List: cabane fitting question
RE: Pietenpol-List: cabane fitting question
Ken,Do you have Long Fuse plans? In those plans it is noted as a 3" "filler".Whatever you decide to do, you must ensure that the distance between theforward and rearward fittings corresponds with the distance between thestruts, thereby preserving a parallelogram with the longerons, cabanes andcenter section. That allows you to move the center section back withoutchanging the angle of incidence. Gary BootheNX308MB
Original Posted By: Jim Boyer
Re: Pietenpol-List: cabane fitting question
Subject: Re: Pietenpol-List: cabane fitting question
Pietenpol-List: Re: cabane fitting question
Ken,Check this out:http://forums.matronics.com/viewtopic.p ... 322880Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 4 Jul 2012 13:50:34 -0700 (PDT)
Re: Pietenpol-List: Re: cabane fitting question
Subject: Re: Pietenpol-List: Re: cabane fitting question
