Pietenpol-List: Larry's brakes
I haven't been able to see any of your pics Larry so I'm not sure of yourexact setup. My point was to just keep in mind that as the axle goes up anddown, the cable connecting your caliper to the strut will form an arc on thecaliper end and to make sure your actuating cable will accommodate allpossible movement without wear or kinking. The axle doesn't move that muchand it's probably pretty minimal, but something worth considering.DouweCan you send me a pic of your plane offline as an attachment? I'm dying tosee it!! Hear it has a nice engine.________________________________________________________________________________Date: Mon, 9 Jul 2012 07:46:20 -0700 (PDT)
Pietenpol-List: Re: Brat Fest 2012
Original Posted By: "K5YAC"
I ran all of mine under the fabric. I ran a piece of 1/2 inch nylon tubing that serves as a conduitFor the ignition wires on the right and for the oil pressure tube on the left. TheOil temp line is the only one not replacableBen CharvetSent from my iPhoneOn Jul 9, 2012, at 10:46 AM, Michael Perez wrote:> I am in the early stages of figuring out how to run the various wires, tubes, cables from the cockpit to the engine. I know some have run these items through the cockpits inside the plane and others run them outside the fuselage, under the fabric. Others use a combination of inside and out. Are there any items that should only be placed inside the cockpits for ease of maintenance/repair? What have you all done with your various engine controls, wires, gage tubes, etc.?> > Michael Perez> Pietenpol HINT Videos> Karetaker Aero> www.karetakeraero.com> > ============================================================================================================================================> ________________________________________________________________________________Subject: Pietenpol-List: Re: Brat Fest 2012
Looking forward to it Jack!--------Mark ChouinardWings, Center Section and Empannage and Fuse framed up - Working on Landing GearRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
