Hey folks=2C I was on the list a few years ago=2C and have been unsubscribed for some time. I was never able to really get started due to health issues my wife has. I am only on to let you know I need to get rid of my project. I have the wood for the fuse=2C wing ribs=2C and tail group. It is all Spruce. I got most all of it from Carl Levkin=2C who was=2C and still may be a member here. He gave me the wood for the tail group. Carl also gave me the the wood for the fuse for a donation to his EAA chapter=2C in Compton. He cut the wood up for me for the fuse=2C and cut the stringers to be laminated. He said this would be stronger. Anyway=2C I believe I donated 75.00 bucks to the Compton EAA group for the fuse wood.I bought the wood for the ribs from a member here for I think around 100.00=2C and I would like to pass this on to someone who might have the time and where withall to use for they're project. Carl was way kind to me while we were in communication=2C and I would like to further his kindness to someone else=2C pay ot forward so to speak!! I will take 100.00 for the fuse wood=2C and also have a Corvair engine I was going to retrofit for this plane as well. The engine is all apart=2C but Carl had my shaft drilled and tapped for the safety shaft needed to install the prop and adapter for same. I am moving=2C and need to find a home for this stuff=2C hopefully someone who will use it. 100.00 bucks gets it all. As I said=2C I don't know if Carl is still around=2C if he is and some here know him=2C give him my regards=2C he was a fine man. I wish I could have done him right by getting the Piet built=2C but reallity says it is not to be. I also have a wing rib Jib that a Gent from Down San Diego way gave me. I remeber his name as Gene=2C and I believe right before I unsubscribed from this list=2C he got his airworthiness Cetificate for his Piet. I contacted him to see if he wanted the jib back but don't think I ever heard back from him. If he is still on this list=2C the jib is his=2C if not=2C it will be part of the deal here for a hundred bucks. Please take me up on this deal=2C but only if you intend on using the material to build a Piet. I am moving and it needs to go by the 21st of January. Thanks=2C Doug Blackburn=2C Yucaipa Californianine oh nine - seven nine zero - zero five three zero home phone=2C call untill 10:00 p.m. P.S. I won't ship=2C don't have time=2C so work something out with someone here on the West Coast if you are interested=2C it really needs to be gone in two weeks. Doug/Elizabeth BlackburnYucaipa CaliforniaISR Rocks www.inlandsloperebels.com ________________________________________________________________________________Subject: Pietenpol-List: Continetal Gauges
