Pietenpol-List: Cold Sortie
Well John, I must say that you have done an outstanding job on the newsletter.I received my issue today and have read it cover to cover. Kudos. Thank you for taking time away from flying to give us folks something to read andhold on to.Cheers,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Cold Sortie
Original Posted By: Rick Schreiber
Cold Recon.. 40 deg on ground..32 aloft. Not too shabby if you suit up. I can easilysee x-country in cold wx...nosighttp://youtu.be/JAo89ONwokU--------KLNCA65-8N2308CAN HardwareAirframe 724TTW72CK-42 SensenichStandard Factory GN-1Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 26 Feb 2014 19:35:30 -0600
Pietenpol-List: Re: prop is done
Nice!!!!Sent from my iPhone> On Feb 26, 2014, at 5:35 PM, Rick Schreiber wrote:> > I just heard from Jay and Carmen Anderson at Cloudcars Props and my prop is done and ready for shipping! Its the one in the center of the photo. If any one is interested the other two props, they are sister props to mine and are available from Jay. The props are reverse rotation for a Corvair engine, 68 inches x 34 pitch. This is the same prop style and specs that Kevin Purtee and others have used on Corvair powered Piets. > > > > Jay may also have another similar prop available, but 68" x 29 pitch. This is the first prop that Kevin started with. Her is a picture of the prop on my Piet last year......> > > > If anyone is interested in these props contact Jay at cloudcars@verizon.net> > Rick Schreiber> NX478RS> Valparaiso, IN> > ________________________________________________________________________________Subject: Pietenpol-List: Re: prop is done
For some reason I thought that Kevin had been flying a 66" ground-adjustable prop.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 26 Feb 2014 20:26:30 -0600
Well, I'll have to go back to see if Kevin ever posted any observations on howthe Cloudcars performed relative to the Warp Drive. Appearance wise, there isno comparison... the sword of Abdullah wins the prize! Time for an archive search...--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: prop is done
Pietenpol-List: Re: Air-Ground Communications
I'll save everyone else the trouble of searching for Kevin's post. Here it is(snipped):========Ive taken so much abuse for the ugly-but-effective Warp Drive prop that I brokedown and bought a wooden prop from Cloudcars. It is 68x34. They originallysent me a 68X27 which Jay calculated to be similar in pitch to my Warp at 7.5degrees. It wasnt enough pitch. They very kindly provided another propeller.It appears to have a little more functional pitch than the Warp. The planeclimbs a little slower, but still at better than 500 fpm, and flies about 10%faster. Since were not allowed to fly our Cloudcars in the rain I may switchto the Warp for traveling to and from Brodhead, and then use the pretty woodenprop while there.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Air-Ground Communications
