Pietenpol-List: Wavy Okoume Plywood Leading Edge
Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeled with ribs, compression struts and leading edge glued). I used cargo straps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunken or wavy between several of the ribs (picture). The other wing seems OK with a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through the fabric (not having covered an airplane before). I want to remove it and try over. Any ideas of what went wrong? Any ideas on how to remove it?Tim WhiteOcklawaha, Fl________________________________________________________________________________
RE: Pietenpol-List: Wavy Okoume Plywood Leading Edge
Original Posted By: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim White
Tim,Were the cargo straps directly on top of the ribs? If so, I don't think they couldhave caused the deformation. You said you glued them two weeks ago andthen moved them to Florida. How long have they been in Florida? I suspect thatFlorida is the culprit. Being very humid, the Florida air will make the plywoodswell and deform between the ribs. Can you move the wing(s) into a heatedspace and let them acclimate for a couple of weeks? If so, I expect you'llfind that they smooth right out.Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Original Posted By:> aa5flyer(at)gmail.com
How to remove it: Heat the plywood surface over a glue joint with a hot iron. The joint will separate like peeling a post-it note.Lorenzo> To: pietenpol-list(at)matronics.com
Toe-in is BAD for a tailwheel airplane. Imagine this, While on the runway youloose directional control. The plane heads off to the right, the left wheel willbe carrying the majority of the loads. If that wheel is "Toed-in" it willhave the tendency to tuck in under the plane. Another words, it will want toturn right. Hold your hands out in front of you, on a vertical plane. These are your wheels,Toe your hands in, Now turn right with both hands. You will see that the outsidehand will want to turn tighter since it is aimed at a different directionthen the forward direction of the fuselage. The best adjustment will be to have both wheels pointed straight ahead. Zero toe-inor toe-out. The trick is to get the wheels straight while the plane is inthe 3pt attitude and while in the level position. This is why a straight axle arrangement works so well.Happy landings,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 4 Nov 2015 07:18:43 -0800
Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
Original Posted By: goffelectric(at)comcast.net
Tim when I did mine, same conditions, temp, humidity, etc, I had one turn out perfectand the other with a dip in each bay. Hoping the fabric pulls it down...Sent from my iPadJack Textor> On Nov 4, 2015, at 7:53 AM, Tim White wrote:> > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeledwith ribs, compression struts and leading edge glued). I used cargo strapsaround each rib and clamps on the font edge to secure it while curing. Broughtthe wing to Florida for the winter and found the plywood was sunken or wavybetween several of the ribs (picture). The other wing seems OK with a slightbulge on the plywood away from the leading edge. I am at a loss to determinehow this happened unless I got the cargo straps too tight. I assume this deformationwill transmit through the fabric (not having covered an airplane before).I want to remove it and try over. Any ideas of what went wrong? Any ideason how to remove it?> > Tim White> Ocklawaha, Fl> ________________________________________________________________________________Date: Wed, 4 Nov 2015 17:33:07 +0000 (UTC)
Original Posted By: David
Tim just an idea... If you have not varnished yet, wet the underside of one baywith a cloth and see how it dries. Maybe heat with an iron???Sent from my iPadJack Textor> On Nov 4, 2015, at 7:53 AM, Tim White wrote:> > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeledwith ribs, compression struts and leading edge glued). I used cargo strapsaround each rib and clamps on the font edge to secure it while curing. Broughtthe wing to Florida for the winter and found the plywood was sunken or wavybetween several of the ribs (picture). The other wing seems OK with a slightbulge on the plywood away from the leading edge. I am at a loss to determinehow this happened unless I got the cargo straps too tight. I assume this deformationwill transmit through the fabric (not having covered an airplane before).I want to remove it and try over. Any ideas of what went wrong? Any ideason how to remove it?> > Tim White> Ocklawaha, Fl> ________________________________________________________________________________
Re: Pietenpol-List: Is this meant to be a Piet?
http://www.cnn.com/2015/10/22/africa/as ... insiteThis is the plane that Asmelash Zeferu will attempt to take off in -- despite having never flown before. The Ethiopian researched for over 10 years before spending 570 days building the plane, modeled on one used to train pilots in the U.S. during the 1920s and 30s.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________________________________________________________________________________Date: Wed, 4 Nov 2015 15:29:48 -0600Subject: Re: Pietenpol-List: Is this meant to be a Piet?
http://www.cnn.com/2015/10/22/africa/as ... insiteThis is the plane that Asmelash Zeferu will attempt to take off in -- despite having never flown before. The Ethiopian researched for over 10 years before spending 570 days building the plane, modeled on one used to train pilots in the U.S. during the 1920s and 30s.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________________________________________________________________________________Date: Wed, 4 Nov 2015 15:29:48 -0600Subject: Re: Pietenpol-List: Is this meant to be a Piet?
Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
A GN-1...obviously the town stud...Sent from my iPadJack Textor> On Nov 4, 2015, at 3:29 PM, Steven Dortch wrote:> > Built to plans. Heck I may try the exhaust shield.>> On Nov 4, 2015 2:20 PM, "David" wrote:>> http://www.cnn.com/2015/10/22/africa/as ... f=obinsite>> >> ________________________________________________________________________________Date: Wed, 4 Nov 2015 19:55:23 -0200Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
RE: Pietenpol-List: Is this meant to be a Piet?
He might save some weight by taking the sprockets off the motorcycle wheels.
Pietenpol-List: Re: Is this meant to be a Piet?
Original Posted By: Jack
He could be one of us on this list. He obviously has access to a computer to watchyoutube. Makes a guy want to go down there and help they poor fella out. We could takeup a collection and at least send him a suitable engine. On second thought, hewon't get too hurt with only a VDub engine. It's safer for him that way. Gives a new meaning to "Your results may vary"--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: Finally on the Gear!
Charles I used brads on mine...Sent from my iPhone> On Nov 4, 2015, at 3:55 PM, "Charles N. Campbell" wrote:> > Next time make sure the cargo straps are on a rib location. C> >> On Wed, Nov 4, 2015 at 11:53 AM, Tim White wrote:>> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge (trammeled with ribs, compression struts and leading edge glued). I used cargo straps around each rib and clamps on the font edge to secure it while curing. Brought the wing to Florida for the winter and found the plywood was sunken or wavy between several of the ribs (picture). The other wing seems OK with a slight bulge on the plywood away from the leading edge. I am at a loss to determine how this happened unless I got the cargo straps too tight. I assume this deformation will transmit through the fabric (not having covered an airplane before). I want to remove it and try over. Any ideas of what went wrong? Any ideas on how to remove it?>> >> Tim White>> Ocklawaha, Fl> ________________________________________________________________________________Subject: Pietenpol-List: Re: Finally on the Gear!
Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Original Posted By: "tools"
Here's a link to a previous discussion on toe-in/toe-out. At the end there's anarticle from the old SAA magazine "To Fly."http://forums.matronics.com/viewtopic.p ... =toeinBill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Original Posted By: Semih Oksay
Looks like the plywood swelled. If heating removes it successfully, might layback down alright.Maybe get the wing somewhere air conditioned and see if the problem corrects itself.Then varnish it. Under tension, should be alright, as in if it moves to a condition of less humidity.Aluminum skins can do the same thing if installed cold, and then put in the sun.Recommend varnishing as soon as practical after installation to help stabilizethe wood with respect to moisture content.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By:> ** owner-pietenpol-list-server(at)matronics.com [mailto:
Subject: Re: Pietenpol-List: Is this meant to be a Piet?Looks ok compared to some homebuilts. I would check cg very carefully=8B andthe power plant? Obviously a Piet inspired project. Can we reach and warnhim about at least cg if all else is fine?Semih2015-11-05 0:04 GMT+02:00 The real bike Mike :> He might save some weight by taking the sprockets off the motorcycle> wheels.>>
Re: Pietenpol-List: Re: Finally on the Gear!
Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading EdgeI looked at the photo carefully. The plywood was glued correctly. This isnot a cargo strap location error. It seems like moisture problem. I havebeen to Florida and know about the humidity. Heating is a solution but I donot recommend local heating with a gun. A few days in a dry room shouldmake it fine. If you have a problem about drying the room, please contactme. In addition, never varnish one side of a thin plywood or veneer andforget it. It curves towards the varnished side because one day moistureswells the unvarnished side.my 2=8B centsHappy landingsSemih2015-11-05 1:05 GMT+02:00 Jack :> Charles I used brads on mine...>> Sent from my iPhone>> On Nov 4, 2015, at 3:55 PM, "Charles N. Campbell" charlescampbell1924(at)gmail.com> wrote:>> Next time make sure the cargo straps are on a rib location. C>> On Wed, Nov 4, 2015 at 11:53 AM, Tim White wrote:>>> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge>> (trammeled with ribs, compression struts and leading edge glued). I used>> cargo straps around each rib and clamps on the font edge to secure it while>> curing. Brought the wing to Florida for the winter and found the plywood>> was sunken or wavy between several of the ribs (picture). The other wing>> seems OK with a slight bulge on the plywood away from the leading edge. I>> am at a loss to determine how this happened unless I got the cargo straps>> too tight. I assume this deformation will transmit through the fabric (not>> having covered an airplane before). I want to remove it and try over. Any>> ideas of what went wrong? Any ideas on how to remove it?>>>> Tim White>> Ocklawaha, Fl>>>>-- Semih Oksay________________________________________________________________________________Subject: Re: Pietenpol-List: Re: Finally on the Gear!
Original Posted By: Tim White
Bill thanks once again for your thoughtful info...Sent from my iPadJack Textor> On Nov 4, 2015, at 8:52 PM, "Bill Church" wrote:> > > Here's a link to a previous discussion on toe-in/toe-out. At the end there'san article from the old SAA magazine "To Fly."> http://forums.matronics.com/viewtopic.p ... ight=toein> > Bill C.> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 747#448747> > > > > > > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
they wereOn 11/4/2015 4:55 PM, Charles N. Campbell wrote:> Next time make sure the cargo straps are on a rib location. C>> On Wed, Nov 4, 2015 at 11:53 AM, Tim White > wrote:>> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading> edge (trammeled with ribs, compression struts and leading edge> glued). I used cargo straps around each rib and clamps on the> font edge to secure it while curing. Brought the wing to Florida> for the winter and found the plywood was sunken or wavy between> several of the ribs (picture). The other wing seems OK with a> slight bulge on the plywood away from the leading edge. I am at a> loss to determine how this happened unless I got the cargo straps> too tight. I assume this deformation will transmit through the> fabric (not having covered an airplane before). I want to remove> it and try over. Any ideas of what went wrong? Any ideas on how> to remove it?>> Tim White> Ocklawaha, Fl>>________________________________________________________________________________Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
Original Posted By:> owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Tim White
Jack,It is 90 degrees with up to 100% humidity (some places setting records). I was very careful to put the straps directly on the ribs. I'm going back to Ohio for the holidays, think I'll let them sit until the heat and humidity go down in January. Thanks much for your help.TimOn 11/4/2015 9:17 AM, Jack Philips wrote:>> Tim,>> Were the cargo straps directly on top of the ribs? If so, I don't think theycould have caused the deformation. You said you glued them two weeks ago andthen moved them to Florida. How long have they been in Florida? I suspectthat Florida is the culprit. Being very humid, the Florida air will make theplywood swell and deform between the ribs. Can you move the wing(s) into a heatedspace and let them acclimate for a couple of weeks? If so, I expect you'llfind that they smooth right out.>> Jack Phillips> NX899JP> Smith Mountain Lake, Virginia>> -----Original Message-----
Original Posted By:> > aa5flyer(at)gmail.com
Lorenzo,Thanks for the tip. I'm going to let it sit for a while until the heat and humidity goes down and see what happens. Might still have to take it off.TimOn 11/4/2015 9:20 AM, larharris2 Harris wrote:> How to remove it: Heat the plywood surface over a glue joint with a > hot iron. The joint will separate like peeling a post-it note.>> Lorenzo>>> > To: pietenpol-list(at)matronics.com
Think I'm going to wait until the heat and humidity goes down. Meanwhile, I'll work on the center section. Thanks to all who replied.Tim WhiteOn 11/5/2015 2:09 AM, Semih Oksay wrote:> I looked at the photo carefully. The plywood was glued correctly. This > is not a cargo strap location error. It seems like moisture problem. I > have been to Florida and know about the humidity. Heating is a > solution but I do not recommend local heating with a gun. A few days > in a dry room should make it fine. If you have a problem about drying > the room, please contact me. In addition, never varnish one side of a > thin plywood or veneer and forget it. It curves towards the varnished > side because one day moisture swells the unvarnished side.>> my 2 cents>> Happy landings>> Semih>> 2015-11-05 1:05 GMT+02:00 Jack >:>> Charles I used brads on mine...>> Sent from my iPhone>> On Nov 4, 2015, at 3:55 PM, "Charles N. Campbell"> > wrote:>>> Next time make sure the cargo straps are on a rib location. C>>>> On Wed, Nov 4, 2015 at 11:53 AM, Tim White > > wrote:>>>> Two weeks ago I glued (T-88) 1/16" Okoume plywood to my>> leading edge (trammeled with ribs, compression struts and>> leading edge glued). I used cargo straps around each rib and>> clamps on the font edge to secure it while curing. Brought>> the wing to Florida for the winter and found the plywood was>> sunken or wavy between several of the ribs (picture). The>> other wing seems OK with a slight bulge on the plywood away>> from the leading edge. I am at a loss to determine how this>> happened unless I got the cargo straps too tight. I assume>> this deformation will transmit through the fabric (not having>> covered an airplane before). I want to remove it and try>> over. Any ideas of what went wrong? Any ideas on how to>> remove it?>>>> Tim White>> Ocklawaha, Fl>>>>>>> -- > Semih Oksay________________________________________________________________________________Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
Original Posted By:>> owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-l
Does this mean that you may fly only in hot, dry areas? Maybe the leading edges should be installed only during maximum humidity conditions? I live in hot, dry California where I installed my leading edges. What will happen if I fly back to Brodhead? Assuming, of course, that I would/could do such a thing?Ray KrauseSent from my iPad> On Nov 5, 2015, at 4:07 AM, Tim White wrote:> > > Jack,> > It is 90 degrees with up to 100% humidity (some places setting records). I was very careful to put the straps directly on the ribs. I'm going back to Ohio for the holidays, think I'll let them sit until the heat and humidity go down in January. Thanks much for your help.> > Tim> >> On 11/4/2015 9:17 AM, Jack Philips wrote:s.com>>> >> Tim,>> >> Were the cargo straps directly on top of the ribs? If so, I don't think they could have caused the deformation. You said you glued them two weeks ago and then moved them to Florida. How long have they been in Florida? I suspect that Florida is the culprit. Being very humid, the Florida air will make the plywood swell and deform between the ribs. Can you move the wing(s) into a heated space and let them acclimate for a couple of weeks? If so, I expect you'll find that they smooth right out.>> >> Jack Phillips>> NX899JP>> Smith Mountain Lake, Virginia>> >> -----Original Message-----
Original Posted By: "wheelharp"
I can't imagine how difficult it would be to acquire quality building materialsand tools to build with there. It makes me appreciate even more everything Ihave access to here.That said, it looks like his left wing trailing edge is warped downwards prettybad...hopefully that gets corrected before he attempts flight again (which Ithink is this month?)--------Jon JonesIronton, MORead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Is this meant to be a Piet?
Here is difference in angle that I see.--------Jon JonesIronton, MORead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/angl ... ______Date: Thu, 5 Nov 2015 11:53:52 -0800
Is there a way to see if he is on this forum? Is it possible to get his email address?Come on, you computer geeks?Ray KrauseSent from my iPad> On Nov 5, 2015, at 9:25 AM, wheelharp wrote:> > > Here is difference in angle that I see.> > --------> Jon Jones> Ironton, MO> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 781#448781> > > > > Attachments: > > http://forums.matronics.com//files/angle_125.jpg> > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Re: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Original Posted By: "Andre B. Charvet"
WF2,Laminar flow? Really?On a Pietenpol wing?Wonder how 6-ply hard cardboard might fare.You know, as shown in the plans.I don't think the use of Okoume vs Aircraft ply is an issue here.BCRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 06 Nov 2015 07:19:11 -0500Subject: Re: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
WF2,In your wing pic, there are two aets of green structural items; one of which isclearly part of the wing itself. The other appears to be some form of wing stand...Would you care to show a few pics of the stand, and tell us how is works, etc.?Thanks!--------Tom KreinerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Is this meant to be a Piet?
This guy has great ambitions. I picked up the phone yesterday and called EAA tosee if they knew about this fella. I'm thinking that it would be a kind jesterto bring him to Osh next year so he can see how it should be done. Long storyshort, It was lunch time in Osh so I didn't get a chance to speak with anyone.If you look closely you can see all the nails or screws he use to attach the coveringmaterial to the longerons. I think at best this gentleman has somethinghe might be able to taxi around a little. There is not enough power there toeven get the tail off the ground. Nothing is straight and all the cables arejust kinda tied on with knots. I may try and call EAA again today if I get a chance. I think the best help wecan offer him is to mentor him for his next project.He has registration numbers on it so I'm sure EAA could find him that way. I don'tthink that CNN would give up the guys contact information to any of us commonfolk. Maybe to EAA, but not us.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
What plywood did you use? Source? Thickness?Tim WhiteOn 11/5/2015 3:54 PM, womenfly2 wrote:>> The lead edge is very critical to the airflow and must be have a very smoothtransition or you will not have an laminar airflow which could stall the wingat higher airspeed.>> Issue with not using aircraft grade plywood ... ? Did a plywood leading edgeon my Piper L-4, still smooth as when I applied it. See pictures on my link below.>> Remove and start over .... no covering will help it and if reworked with heat,will come back later with humidity changes. Apply new skins and seal right awayto stabilize the wood.>> Be safe!> WF2>> -------->>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 6 Nov 2015 12:55:14 -0200Subject: Re: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Original Posted By: "simmor2"
https://www.facebook.com/asmelash.zeferuRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Oscar/Steve,Thanks for the info. I really considered the Flybaby because of the leg room but,although I seldom have a passenger, I like having the extra seat just in case.And yes, the shade will be handy;)Thanks,BillRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Original Posted By: "Boatright, Jeffrey"
I used Finnish plywood of 1mm thick about 3/64" from Aircraft Spruce. Their P/N:02-50000My web site should work click on lnk below, but if not copy and paste in your browser:Your wing surface should be smooth as possible. Good luck.WF2--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
The world does not have a duty...Big time engineer named Octave sure helped a couple of quack brothers from someweird place in Oh-hi-yo a few years ago...Sent from an iPhone with a spelling problem> On Nov 7, 2015, at 8:08 PM, taildrags wrote:>>> People have dreamed of flying since the creation. This gentleman in Ethiopiais doing better than a lot have done, but the world does not have a duty to helpevery dreamer make every contraption safe any more than it has a responsibilityfor what the results of the experiment are. You can bore yourself watchingvintage videos of early attempts at flight, but here's a 7-minute sampling:>> https://www.youtube.com/watch?v=Sp7MHZY2ADI>> Some are entertaining, some are sad, a few are novel, a few were successful.The Ethiopian fellow's project is just one more in an almost timeless progressionof attempts to make wings and fly.>> --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ______This e-mail message (including any attachments) is for the sole use ofthe intended recipient(s) and may contain confidential and privilegedinformation. If the reader of this message is not the intendedrecipient, you are hereby notified that any dissemination, distributionor copying of this message (including any attachments) is strictlyprohibited.If you have received this message in error, please contactthe sender by reply e-mail message and destroy all copies of theoriginal message (including attachments).________________________________________________________________________________Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Bill Church wrote:> WF2,> > Laminar flow? Really?> On a Pietenpol wing?> > Wonder how 6-ply hard cardboard might fare.> You know, as shown in the plans.> > I don't think the use of Okoume vs Aircraft ply is an issue here.> > BCYes, really. All airfoils rely on laminar flow. That is different than a laminarflow airfoil, which is specifically designed to exploit laminar flow. The opposite of laminar flow is turbulent flow, as seen during boundary layer separation,which nearly defines a stall. Do the original plans call for gluing or nailing the leading edge skins? Nailingwould allow the skin to move with moisture content variation.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Okay, maybe I misread the original statement.Having a smooth transition between the leading edge and the plywood attached toit is important, since this is the only part of the wing that will experiencelaminar flow (probably not more than the first 6" or so of the Pietenpol airfoilwill experience laminar flow), and roughness or sharp edges would disruptthat.However, after the covering is applied, the fabric will pull down on the plywoodbetween the ribs, effectively changing the airfoil. But it's been that wayfor over 80 years, and seems to be working all right so far.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
It is wishful thinking that the plywood will pull down when the fabric is applied.Never seen that happen, what ever the structures is under the fabric it willbe that way when finished. Every aircraft manufacture will tell you the leadingedge needs to be smooth. In my experience I have no knowledge of it being like that for 80 years, not what I have seen.There is no excuse for not correcting the issues and making it right, deep downwe all what it to be right. Even dents on a Cubs leading edge can make the wingloose lift and needs to be corrected.Be helpful and truthful, all aircraft need to be built with the best skill andpractices possible. If its not right correct it, its your life up there and yourpassenger if you take one .... their entrusting you with their life.WF2--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Maybe there is some confusion by the question. Clearly, the plywood pullsdown between the ribs, even though it starts out as straight. It is saidthat it is preferred not to be supported by a filler on the spar, betweenthe ribs, to allow for it to be pulled down and make a smoother transition. I know for fact that my wing 'grows' during Winter, as I can see the aileronbutt gap get closer when the humidity rises for an extended time (CA). JackPhillips made the best suggestion, to allow it some time in a heatedenvironment, and see if the plywood straightens up...then varnish! Gary BootheNX308MB-----Original Message-----
On my Piet I used 45 degree mahogany plywood, I know its expensive, but I had noissues with it. It stayed pretty smooth in all temperature and humidity conditionshere in NH.One thing is to add some stringers on the leading edge as in a model plane to givethe plywood some support between the ribs too. Helps to keep the shape. ButI really do not see the need for them on a Piet, the sheet area is pretty shortand only on the top. If the wood is dried properly it should absorb very littlemoisture in the bare condition. Seal it as soon as its applied will helpstabilize it too .... sealing both sides at the same time helps.All good input,WF2--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Call it wishful thinking if you want. I prefer to call it observing details.If the plywood skin at the leading edge of the wing is installed per the plans(with no reinforcing at the back edge), the fabric will naturally pull the plywooddown between the ribs, in the same way that the fabric pulls down betweenthe ribs. This is not a drastic deflection, but it certainly is observable.In fact, the two photos supplied by Gary illustrate my point. The first photoshows the uncovered wing structure, with flat plywood. In the second photo,with the wing covered, the deflection of the plywood can be seen at the righthand side of the photo. For another example, see this photo:http://www.westcoastpiet.com/images/Jac ... _136.JPGIn this aircraft, with the airfoil that it has, the trailing edge of the plywoodin question is most likely no longer in the area of laminar flow.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Jack,He sounds very pleased to be making contact with us. I hope we can sincerely helphim in his quest. On his face page he has a lot of pictures of his build. Itall looks quite familiar!RaySent from my iPad> On Nov 9, 2015, at 11:36 AM, Jack wrote:> > > Ray in response to your note to Asmelash I signed him up for the Pietenpol pageand sent him a note with that info and the EAA site.> > Sent from my iPad> Jack Textor> >> On Nov 9, 2015, at 12:06 PM, Ray Krause wrote:>> >> >> Oscar and Jeff,>> >> I have made email contact with Asmelash Zeferu in Africa, thanks to Ryan' ssleuthing! I sent you a copy of my email to him giving him directions to jointhe PIETENPOL Forum. I hope that if he joins the Forum, our members will be helpfuland recognize the great effort he has gone through under very trying circumstances.I have lived in similar countries with like resources, so I recognizehis determination! We should be able to offer helpful encouragement.>> >> He says he has calculated the W/B. >> >> Thanks,>> >> Ray Krause>> >> Sent from my iPad>> >>> On Nov 8, 2015, at 10:02 PM, taildrags wrote:>>> >>> >>> Jeff (Boatright)- thank you for taking me down a notch. As a result of beingon this list I have low and slow aviation friends all over the world and Iam much the richer for it. My intention in making the statement that the worlddoes not owe me (or any other experimental aircraft builder) a duty to helpin our success does not mean that we shouldn't jump in and help when we can. It certainly does NOT mean that we shouldn't try, either. It just means thatsometimes we get individual ideas and visions in our heads and we push forwardwith them no matter what the world around us says. In those cases, we just haveto do what is in our hearts and heads to do, and failure is certainly an optionwhen we buck the trend and the best advice and just push forward anyway.In fact, sometimes our instinct tells us that something probably won't workbut we have to try it to see why it doesn't work and to see if we can find outhow we might be able to make it work. I know this i!> s!>> h!>>> ow "Aviken" feels with his Jeep engine Air Camper project, and how some ofthe rest of you feel with your personalized, "different", custom, unusual, orunorthodox approaches to things.>>> >>> I think that the Ethiopian chap did what he did, the way he did it, becausehe doesn't have a Wicks, or an Aircraft Spruce, or even a Lowe's or Home Depotor Harbor Freight, or an eBay, or Amazon, or Barnstormers, or a credit cardavailable to him. He has a dream and he put it together the best way he knewhow, with what he had available, in spite of what he DIDN'T have. We laugh whenwe watch the video and the prop flies off just after he fires up the engine,but deep inside we didn't want it to just end there. Maybe we would still havelaughed if a wheel fell off after he warmed it up and taxied out, or if anynumber of other awkward things would have happened later- but the video wouldhave gone absolutely viral if his rig would have made it to the runway, andhe throttled it up, and he stumbled and bumbled and bumped it down the runwayfar enough to where it came up onto the mains and got even a foot or two of airunder the tires for even just a few seconds before !> s!>> om!>>> ething else happened and it came crashing back to the ground. And granted,with as much questionable stuff as he had on it, there is no doubt that it wouldhave come down sooner rather than later.>>> >>> We would have cheered the fact that he flew it. We would have felt what hefelt, because we have felt it too. We would have welcomed him into the fraternityof aviators, because he earned it. And maybe he will.>>> >>> Far be it from me to deprive this man from any part of what he has put hisheart and soul to do, and to attempt. I hope he makes it.>>> >>> -------->>> Oscar Zuniga>>> Medford, OR>>> Air Camper NX41CC "Scout">>> A75 power>>> >>> >>> >>> >>> Read this topic online here:>>> >>> http://forums.matronics.com/viewtopic.p ... 007#449007> > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Don't the plans show 28 ga aluminum, which would eliminate any of the seasonalexpansion?--------Jon JonesIronton, MORead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Jon,No, the plans do not show 28ga aluminum. They call for the use of 6-ply hard cardboardor 1/16" plywood. Don't think anybody has used the cardboard optionfor many years, though.Some have used aluminum, but there are issues to contend with if you choose togo that route. One issue is figuring out how to attach the aluminum to the woodenribs. Glue will not work (in the long run), and nails will eventually worktheir way out. Another issue is that aluminum and wood will expand and contractat different rates, as the temperature rises and falls.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Scot and Ray I mentioned WestCoast Piet to him also...Sent from my iPadJack Textor> On Nov 10, 2015, at 11:51 AM, "AircamperN11MS" wrote:> > > Ray,> > Thanks for contacting him. I do not have facebook. It is great that he is offered this site as another resource to him. We need to also let him know about www.westcoastpiet.com as well. > > As others have said, if he reaches out to us, we should do everything we canto help him with his quest. > > Asmelash has great ambition and a great drive. He has proven that to me. WhenI look at the Youtube video, I can't help but wonder which of all those youngfaces in that group he is influencing????? I wonder who influenced him? I wonderif a plane from this group is what gave him inspiration? Maybe he had seenMike Cuy's, Gary Boothe's, Tools, or even my plane? Hard to say. But we allare the guys and gals who are keeping Bernie Pietenpol's dream alive. It lookslike it may be his turn in Africa to keep the dream alive. > > I hope to see him on this forum asking questions. > > Cheers all,> > --------> Scott Liefeld> Flying N11MS since March 1972> Steel Tube> C-85-12> Wire Wheels> Brodhead in 1996> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 129#449129> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
Hmmm... I never noticed that before. The Flying and Glider plans actually dosay to use 28ga aluminum on the leading edge of the wing. I have no idea how anyone manages to actually build an airplane using only theplans in the Flying and Glider reprints. Those drawings are so small.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
In Des Moines IASent from my iPhone> On Nov 11, 2015, at 2:46 PM, Tony Crawford wrote:> > Hi,> Do you live anywhere near northern Alabama?> > Tony> >> On Wed, Nov 11, 2015 at 1:26 PM, Jack wrote:>> Tony here is what I found on drawing 4. I'm more perplexed because my existing post is 5 1/2" between the floor bolts. Not sure where I came up with that years ago...>> Jack>> >> >> >> >> >> Sent from my iPad>> Jack Textor> ________________________________________________________________________________Subject: Pietenpol-List: Re: Wavy Okoume Plywood Leading Edge
> > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge > (trammeled with ribs=2C compression struts and leading edge glued). I > used cargo straps around each rib and clamps on the font edge to secure > it while curing. Brought the wing to Florida for the winter and found > the plywood was sunken or wavy between several of the ribs (picture). > The other wing seems OK with a slight bulge on the plywood away from the> leading edge. I am at a loss to determine how this happened unless I > got the cargo straps too tight. I assume this deformation will transmit> through the fabric (not having covered an airplane before). I want to > remove it and try over. Any ideas of what went wrong? Any ideas on how> to remove it?> > Tim White> Ocklawaha=2C Fl ________________________________________________________________________________Subject: Pietenpol-List: Re: Finally on the Gear!
> >> > Two weeks ago I glued (T-88) 1/16" Okoume plywood to my leading edge> > (trammeled with ribs, compression struts and leading edge glued). I> > used cargo straps around each rib and clamps on the font edge to secure> > it while curing. Brought the wing to Florida for the winter and found> > the plywood was sunken or wavy between several of the ribs (picture).> > The other wing seems OK with a slight bulge on the plywood away from > the> > leading edge. I am at a loss to determine how this happened unless I> > got the cargo straps too tight. I assume this deformation will transmit> > through the fabric (not having covered an airplane before). I want to> > remove it and try over. Any ideas of what went wrong? Any ideas on how> > to remove it?> >> > Tim White> > Ocklawaha, Fl________________________________________________________________________________Subject: Re: Pietenpol-List: Wavy Okoume Plywood Leading Edge
