I am putting together a new set of wire wheels, going the route of hubs from KenPerkins being laced to aluminum alloy wheels by Buchanan's. So far so good,but I have not been able to find smooth tires other than the Firestone SmoothClincher at Coker:https://www.cokertire.com/tires/styles/ ... .htmlThese fit a 1.77" rim, I'm not sure what diameter. I'm also not sure what "clincher"means. I know others have used the ribbed Avon M6 Speedmasters, for instance, they lookgreat on Jim Markle's build, but I like the look of the smooth tires. The Avonsare also fairly low profile and I like the look of a larger tire.Does anyone have sources or information on smooth tires?Thanks,JeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 27 Nov 2015 10:35:15 -0800
Pietenpol-List: Source for smooth tires?
Pietenpol-List: Re: Source for smooth tires?
Jeff; I'm not going to be of much help here, but at least you'll have a littlebit of company on a very quiet list ;o) They say that turkey contains some sortof soporific chemical, so maybe that explains why everybody seems to be asleepright now.I have heard this question asked, and more than once I've read where people suggestcutting, grinding, or sanding off the tread, ribs or lugs on a conventionaltire to get them smooth. I'm sure this doesn't leave you with very much lefton the tire, but if you start with 6-ply tires, maybe there will be enoughin the body of the tire to give you a season or two of flying without the normalwear surfaces on your tires. It sounds like the price you may have to payfor the look of smooth tires. The only other place I've seen tires like thatwas on the old open-wheel Indy cars, but those would be much larger than whatyou're interested in.Too bad you don't have 6.00x6s... I could send you my tires after I wear the treadoff them. Couple of hundred landings on pavement seems to do the trick, especiallyin x-winds.--------Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 powerRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
