Original Posted By:> hyvris(at)gmail.com
I did the same. Just use good aircraft/marine three ply plywood and cut without regard for the grain. Life is simple!Ray KrauseBuilding SkyScoutSent from my iPad> On Jan 23, 2016, at 8:29 AM, larharris2 Harris wrote:> > Welcome, Petr.> Maybe others will disagree, but I did not care about direction of grain in the gussets. Gusset material is plywood. Interior layers of the ply will have grain direction 90 degrees to the surface ply. I tried to cut my gussets to make the best use of my material, with the least waste.> > Lorenzo> > > Date: Sat, 23 Jan 2016 15:34:14 +0100> Subject: Pietenpol-List: gussets grain orientation - empenage (rudder,fin,elevator,stabilizator)
