Pietenpol-List: My measuring mistake
Original Posted By: "Pocono John"
Subject: Re: Pietenpol-List: Re: Pietenpol-List Digest: 3 Msgs - 01/18/17Engineers use their personalities for birth control!On Jan 22, 2017 12:29 PM, "taildrags" wrote:>> Steve: no, I don't know what engineers use for birth control, but I'll bet> you have an angle ;o)>> --------> Oscar Zuniga> Medford, OR> Air Camper NX41CC "Scout"> A75 power, 72x36 Culver prop>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: My measuring mistake
Pietenpol-List: Re: My measuring mistake
I've discovered my tail post is 1" too tallit's 11 7/8". This "too tall" mistakecarries forward to the pilot seat back where the fuselage is 3/8" too tall (thestart of the error).I'm about to dig the nails from gussets before I start the job of gusset removal.I was wondering how much of an affect that extra inch would have on weight & balanceas well as handling characteristics; the rudder would have to be increasedan inch.Just something to ponder on a dreary day here.John--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: My measuring mistake
John,I am building a Piet with a steel tube fuselage, so my questions only come fromlooking at the plans, not actual experience building the wood fuselage. So takeit FWIW.Are your top longerons parallel with the ground, or is there a slight bow in them?If they are have a bow, then my guess is that you have a problem.However, if they are parallel to the ground, then are you saying that the tailpost is an inch too long? In other words, it extends 11 and 7/8' below the toplongeron? If so, can you not just make the vertical stabilizer 44 and 1/2", not43 and 1/2", as the plans show?Builders of the wood fuselage may throw a rock at me for suggesting it, but thatis just my initial thought.--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Steve,I thought that that was what air line pilots use. [Laughing] [Wink]--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: My measuring mistake
Thanks Terry. The problem is at the lower longeron. When laying out the jig, Iapparently measured 10 7/8" from the outside of the top longeron and made my markfor the bottom longeron, but placed the inside (not outside) of the bottomlongeron there, giving me a tail post 1" too long.The top is straight. If I leave it as it is, I'll have to extend the rudder aninch. I'm not sure what else could be affected. I'm trying to stick to the plans,so this irritates me.I'm curious, though, how much that 1" would affect the aircraft. It's a gentlecurve from the tail to pilot seat back where the plane would be only 3/8" tootallJohn--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: My measuring mistake
Gotcha.I defer to my wooden brethren.--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: "tools"
Subject: Re: Pietenpol-List: Re: Spring Landing Gear designsDid you buy large washers for the tube caps, or make your own?Sent from my iPhone> On Jan 22, 2017, at 6:13 PM, aviken wrote:> > > I built my gear using the WW die spring method. I got my springs form AS> and built them close to his plans as possible . I did connect mine to the landinggear attatchment point and not to a center v as some do . I have beenvery happy with the set up> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 348#465348> > > > > Attachments: > > http://forums.matronics.com//files/land ... _1_886.jpg> > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Re: My measuring mistake
Really, I doubt it would matter at all. Folks use all manners of tailwheels, somewhich change their own weight by that much as they wear.Aerodynamically, cannot it would matter either. This airplane lives in the middleof a wide range of good. About the only hinky thing is weight and balance,which should be checked anyway, and which is correctable for that minor amountof weight a thousand ways. The real issue is how YOU feel about it. Fixable with a lot of work, about twobucks of epoxy, and five bucks worth of wood. This plane was designed for 150 lb pilots, but 200 lb'ers are flying it. Nicespruce but dense doug fir is used. 1/16 wires but 3/32 is used... This isn'tthat big of a deal. I'm a fan of build to fix anyway, rather than strict plancompliance. FEW eyes are calibrated to one inch on this plane. Might matteron a Queen Anne period reproduction... But not this! In fact I'll bet things like cockpit wing cutouts, and scalloped trailing edgeschange the square inch amount of rudders and stabs more than this.MikeRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Spring Landing Gear designs
Original Posted By: Jack Textor
Ben,I had posted this on the Pietvair forum a while back. But since you are unableto see that, I am sharing here. The spring shown is the one I used, and it isa good bit cheaper than what can be found elsewhere. I hope the info helps.--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/img_ ... __________
Subject: Re: Pietenpol-List: Re: Spring Landing Gear designsBen I bought mine at a local FastenalJack TextorSent from my iPad> On Jan 22, 2017, at 5:19 PM, Ben Charvet wrote:> > > Did you buy large washers for the tube caps, or make your own?> > Sent from my iPhone> >> On Jan 22, 2017, at 6:13 PM, aviken wrote:>> >> >> I built my gear using the WW die spring method. I got my springs form AS>> and built them close to his plans as possible . I did connect mine to thelanding gear attatchment point and not to a center v as some do . I have beenvery happy with the set up>> >> >> >> >> Read this topic online here:>> >> http://forums.matronics.com/viewtopic.p ... 348#465348>> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/land ... _1_886.jpg>> >> >> >> >> >> > > > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Re: Spring Landing Gear designs
Terry,I can' t open the attachmentsBenOn 1/22/2017 6:59 PM, jarheadpilot82 wrote:>> Ben,>> I had posted this on the Pietvair forum a while back. But since you are unableto see that, I am sharing here. The spring shown is the one I used, and it isa good bit cheaper than what can be found elsewhere.>> I hope the info helps.>> --------> Semper Fi,>> Terry Hand> Athens, GA>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.p ... 353#465353>>> Attachments:>> http://forums.matronics.com//files/img_6219_837.jpg> http://forums.matronics.com//files/die_ ... _1_156.pdf> http://forums.matronics.com//files/die_ ... ___Subject: Pietenpol-List: Re: Spring Landing Gear designs
Original Posted By: "aviken"
Ben, I had posted this on the Pietvair forum a while back. But since you are unableto see that, I am sharing here. The spring shown is the one I used, and it isa good bit cheaper than what can be found elsewhere. I hope the info helps.--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/die_ ... ___Subject: Pietenpol-List: Re: Spring Landing Gear designs
I believe I bought large washers at the local hardware store. Seems I did haveto do some grinding work to get them to fit.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: My measuring mistake
Thanks Mike.I appreciate the post.John--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: My measuring mistake
John;What's funny is that I have seen discussions about how if the airplane is built to the plans, the lower edge of the rudder protrudes below the tailpost just a little. So, it may be that you're ahead of the game ;o) Here's an example, Chuck Gantzer's Piet: http://www.westcoastpiet.com/images/Chu ... .jpgHere's another, Gary Boothe's:http://www.westcoastpiet.com/images/Gar ... 823.JPGAnd another, Kevin Purtee's:http://www.westcoastpiet.com/images/Gar ... 823.JPGAnd finally, you can see in this very close-up photo of Kurt Shipman's airplanethat if you don't flatten or round-off that very last bit of the rudder, it willbe just a bit longer than the bottom of the tailpost and won't fair into theline of the lower longeron.http://www.westcoastpiet.com/images/Kur ... -----Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 power, 72x36 Culver propRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: My measuring mistake
Original Posted By: "JERRY"
...whoops... here's Purtee's Fat Bottom Girl:http://www.westcoastpiet.com/images/Kev ... -----Oscar ZunigaMedford, ORAir Camper NX41CC "Scout"A75 power, 72x36 Culver propRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Chuck,Try again. Try right clicking on the pictures, and then you should be able to savethem to your own computer. The pictures are also on the Pietvair Forum.--------Semper Fi,Terry HandAthens, GARead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: My measuring mistake
Thanks Oscar.very interesting. I'll check those links.John--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
