Hey Folks - I am looking for a fuel tank for the front, inside of the fuselage just ahead of the passenger seat.
I have heard that some folks have used a tank from a Cub.
I do not want much for capacity. Really just for spare and at first for taxi work. I am thinking about 5 gallons.
Any suggestions would be great.
Dave
Front Fuel tank
r1200gsDave
- Contact:
Re: Front Fuel tank
I'm thinking of doing the same.
Disappointed no responses.
Have you found out anything?
Re: Front Fuel tank
I don't know about a Cub tank but here's what the conventional front-mounted tank looks like. Mine holds about 16 gallons so you can see that with just the curved top part, you could get your 5 gallon capacity.
The Grega GN-1 was designed to use quite a few Piper parts, so looking through the GN-1 plans might provide you with information on the use of a Cub fuel tank. I have the Grega plans and can look for them if you're interested, or I can check to see if they employ a Cub tank in the first place.
Re: Front Fuel tank
On my first attempt at a fuel tank, I made one out of fiberglass ... or tried to, at least. What I learned was that I knew just enough about fiberglass to make a mess of it. It was very heavy and leaked.
On my second attempt, I made it out of cardboard and duct tape. After careful measurements, I sent the specs to Carlsons in Ohio where the main jack-of-all-trades guy welded up a tank for me. I'm not sure but it sounds like Carlsons may have closed its doors after selling its strut supplies to Wicks.
In any case, here's a couple pics. My tank has 16 gallon capacity, 14 useable. That's plenty. My butt and back are tired long before I get anywhere near the reserve level.
Re: Front Fuel tank
Both excellent. Was hoping to find something plug-N-play but I am fortunate to have a local lad who makes magic with tig AL. Looks like it’s cardboard and tape for me.
Re: Front Fuel tank
I have a header tank I used in my Pietenpol. It is a 1.4 gal tank used as a supplement to the main tank in the wing. I also have the main 10 gal wing tank available.r1200gsDave wrote: Sun Apr 17, 2022 4:28 pm Hey Folks - I am looking for a fuel tank for the front, inside of the fuselage just ahead of the passenger seat.
Dave
Dave Boyd
217 202 3417
Re: Front Fuel tank
Availabled: I have a front fuel tank (1.4 gal) I used as for W&B purposes and as a back up to my aluminum wing tank (10 gal) which I also have available.
Dave Boyd
217 202 3417
Dave Boyd
217 202 3417
Re: Front Fuel tank
I have a front fuel tank I had build from a 1.4 gal fire extinguisher. I used it as a header tank and for weight and balance. I also have have the main center section tank as per the Piet plans. Call or text to let me know if you're interested.
Dave Boyd
217 202 3417
Dave Boyd
217 202 3417
