Front Fuel tank
r1200gsDave
Front Fuel tank
Post by r1200gsDave »
Hey Folks - I am looking for a fuel tank for the front, inside of the fuselage just ahead of the passenger seat.
I have heard that some folks have used a tank from a Cub.
I do not want much for capacity. Really just for spare and at first for taxi work. I am thinking about 5 gallons.
Any suggestions would be great.
Dave
JimBob
Re: Front Fuel tank
Post by JimBob »
I'm thinking of doing the same.
Disappointed no responses.
Have you found out anything?
Re: Front Fuel tank
I don't know about a Cub tank but here's what the conventional front-mounted tank looks like. Mine holds about 16 gallons so you can see that with just the curved top part, you could get your 5 gallon capacity.
The Grega GN-1 was designed to use quite a few Piper parts, so looking through the GN-1 plans might provide you with information on the use of a Cub fuel tank. I have the Grega plans and can look for them if you're interested, or I can check to see if they employ a Cub tank in the first place.
Re: Front Fuel tank
Re: Front Fuel tank
On my first attempt at a fuel tank, I made one out of fiberglass ... or tried to, at least. What I learned was that I knew just enough about fiberglass to make a mess of it. It was very heavy and leaked.
On my second attempt, I made it out of cardboard and duct tape. After careful measurements, I sent the specs to Carlsons in Ohio where the main jack-of-all-trades guy welded up a tank for me. I'm not sure but it sounds like Carlsons may have closed its doors after selling its strut supplies to Wicks.
In any case, here's a couple pics. My tank has 16 gallon capacity, 14 useable. That's plenty. My butt and back are tired long before I get anywhere near the reserve level.
JimBob
Re: Front Fuel tank
Post by JimBob »
Both excellent. Was hoping to find something plug-N-play but I am fortunate to have a local lad who makes magic with tig AL. Looks like it’s cardboard and tape for me.
dnboyd
Re: Front Fuel tank
Post by dnboyd »
r1200gsDave wrote: Sun Apr 17, 2022 4:28 pm Hey Folks - I am looking for a fuel tank for the front, inside of the fuselage just ahead of the passenger seat.
Dave
I have a header tank I used in my Pietenpol. It is a 1.4 gal tank used as a supplement to the main tank in the wing. I also have the main 10 gal wing tank available.
Dave Boyd
217 202 3417
dnboyd
Re: Front Fuel tank
Post by dnboyd »
Availabled: I have a front fuel tank (1.4 gal) I used as for W&B purposes and as a back up to my aluminum wing tank (10 gal) which I also have available.
Dave Boyd
217 202 3417
dnboyd
Re: Front Fuel tank
Post by dnboyd »
I have a front fuel tank I had build from a 1.4 gal fire extinguisher. I used it as a header tank and for weight and balance. I also have have the main center section tank as per the Piet plans. Call or text to let me know if you're interested.
Dave Boyd
217 202 3417
