It is 70-85% complete, with all parts needed to finish, for more details Text 406-670-6983 or Email at patricktidwell14@gmail.com or through
Facebook messenger.
I am asking for $5000 obo.
Come pick it up In Billings, Montana
I am 18 Years old and very willing to negotiate on the price, motivated to sell (even though the parts alone are worth more than $8000.) If anybody is looking for A Pietenpol with a great head start on the build PLEASE don't be afraid to reach out.
PLEASE MUST BE GONE BY END OF AUGUST OR IT WILL BE THROWN OUT
Current Parts List
Airframe Components
Wood Fuselage Assembly
Wooden fuselage structure
Wood longerons and crossmembers
Wood cockpit side panels with varnished finish
Integrated landing gear mounting structure
Cockpit framework and seat area
Tail mounting structure
Landing gear and tire assembly
Wing Assemblies
Pair of completed wing structures
Fabric-covered
Internal wood rib construction
Wing attachment fittings
Removable control surfaces
Wing inspection/access panels
Wing root fairings
Tail Section
Vertical stabilizer
Rudder assembly
Horizontal stabilizer
Elevator assemblies
Tail framework with fabric covering
Continental A-75 Aircraft Engine
Continental A-75 4-cylinder air-cooled aircraft engine
Engine mount stand
Exhaust manifolds and stacks
Intake manifold system
Carburetor
Oil tank/reservoir
Engine baffling pieces
Fuel hard lines
Flexible induction ducting
Cowling & Exterior Panels
Upper cowling sections
Lower cowling panels
Nose bowl/front cowl
Side engine covers
Inspection/access openings
Yellow-painted aluminum panels
Controls & Systems
Control cables
Push-pull linkage assemblies
Wiring harness sections
Aircraft tubing and plumbing
Cockpit hardware
Instrument gauge(s)
Airspeed
RPM
Altimitmeter
Compass
Oil temperature
Thank You,
Patrick Tidwell
Modified Pietenpol Project, Need help finding it a home
Patricktidwell18
Last edited by Patricktidwell18 on Wed Jul 29, 2026 10:18 pm, edited 1 time in total.
Re: Modified Pietenpol Project, Need help finding it a home
Hello! I am an avid aviator who has been dreaming of building a Piet since I was 14. I would love to give your Piet a home and finish it.. I however cannot afford 8000 sadly been actually looking for grants to help with cost.. Can we talk and hopefully make a deal
