Pietenpol-List: Re: direct drive inline 4s
Posted: Fri Feb 28, 1997 8:13 am
I've had this idea for a while of building a Piet with an inline4 that would be newer than a model A. The engine I had in mindis the NAPS-Z engine used in Nissan light trucks in the mid 80s.It's about 2 litres with a thin iron/alloy block, aluminum heads,forged alloy crank, duplex chain cam drive, and the best feature;DUAL IGNITION.Yup, two plugs per cylinder. The stock system has an 8-wiredistributor. You could install a vertex mag in the distributorhole for one set of plugs and possibly adapt a mag drive offthe camshaft end to run the other set. No electrical systemnecessary.It would be interesting to see the power curve for this motor. Ifit could be made to make 60-70 hp at 2700 rpm direct drive, and weigh no more than the model A, that could be just the ticket.Anybody else with similar ideas?John Kahn ________________________________________________________________________________
