Pietenpol-List: Re: NAPS-Z
Posted: Fri Feb 28, 1997 10:58 am
SteeveeWhat's the biggest displacement for those engines anyway?Figuring on 1/2 hp per cube when turning at 2700 rpm,an engine (bored out if necessary) at 2.2 litres, having atruck cam (torque peak probably around 3000rpm) should be able to make 2.2x61=134 one half of which is 67 hp. Not bad.Probably about 50lbs heavier than an A65 at least though.John________________________________________________________________________________
