For those of you relatively new to the list, repeat messagesoccasionally happen. It is not the fault of the sender, rather the mailserver that I use. I have done my best to fix the problem, but I cannotget rid of it. The problem stems from the fact that we have so manyusers that mail going through the system sometimes times out before mailis sent to all participants, thus it starts again at the top of the listand resends. To help this problem I have tried to limit the number ofparticipants and also weed out bad addresses. You can help by sendingme a message to unsubscribe when you no longer want to be on the list.Also if you are a sys admin with the capability of taking over this liston a more powerful machine I would be glad to give it up to you. Emailme if you are in this position.Stevee________________________________________________________________________________
