Pietenpol-List: Your Progress
Posted: Tue Jul 08, 1997 12:55 pm
Original Posted By: "Robert M. Bailey"
Hi Tom,How's your progress going on covering? You've seen the blurb of my progress posted to the discustion group. With this cool weather the bottom of the fuselage has become a problem to dope. Last night the bottom was re-sanded and another coat of dope sprayed but the same problem re-occured (blushing) so it must be cooling too fast. Another characteristic in some places is a powdery effect. This usually happens when the gun is held too far away from the surface. I held it closer but the same problem occured. At least this is the (last) bottom surfaceof the fuselage. Tonight I'll sand it down again the wait for a little warmer weather. I pulled out my propeller carving machine , set it up to get ready for the next job, and in parallel i'll be preparing the lift struts.Regards,Domenico Bellissimo ________________________________________________________________________________
