Pietenpol-List: Re: propeller thrust line
Posted: Mon Aug 25, 1997 1:46 pm
Original Posted By: jimvan1(at)juno.com (James T. VanDervort)
Working away at my terminal here, the mind wanders from work and...A question pops up...Does anybody on the list know if the Model A's vertical location is dictated by the thrust line or propeller length requirements, or is it that high simply to get the mag mount above the top longeron level.If you used a side mount mag a'la Funk, could you move the engine downa couple inches and still have propeller clearance and reasonableflight characteristics? The idea being to get the top of the engineout of the way as much as possible, and in conjunction with a chin mount rad, get the same forward visibility as with an aircraft engine.Comments?? ________________________________________________________________________________
