Pietenpol-List: Piet Stuff
Posted: Fri Oct 03, 1997 2:11 pm
I have a number of questions that I'd like some feedback on.1. Aileron hinges--Can anyone see a problem with using piano hinges which provide a gap seal at the same time?2. Wing trailing edges--I've used a piece of folded over aluminum with rounded TE. They are rigid, light, and with the fold and the edges bent just a bit more for extra strength, hold up well to fabric pressure. Any comments?3. I'd like to confer with some other builders. Is there anyone out there within 120 miles of Rexburg, ID? I'd also be glad to show and tell.4. Engine--I'm using a Ford Escort with about 80 hp. I know Ed Lubitz pioneered this installation. I have his conversion guide, but I'd like to talk to someone else who is using this type of installation, particularly about radiator placement/air scoop, and also distributor conversion. I have my engine mounted and running--but I also have some doubts, particularly about low end idle. Any comments? I'm repainting my fusalage this weekend after some damage repair. Myplane is on the Jenny-type gear with motorcycle wheels and mechanicalbrakes. I have a one piece wing which just lacks a coat of epoxyvarnish prior to recover with Polyfiber line of products.Thanks, Bill________________________________________________________________________________
