Pietenpol-List: Re: How much does it cost.
Posted: Fri Jun 12, 1998 4:13 pm
I had planned on using a Corvair, but i, too would like to know how much an 'A' can be bought/built for. The choice of a Corvair is not yet set in stone for me.> Ok then how much does it cost to build an "A" engine for the piet.> > Still wanna build one.> Steve-------------------------------------------------Homepage: http://207.140.1.221/w3builderPietenpols: http://207.140.1.221/w3builder/piet____ ... __________
Pietenpol-List: How much does it cost.
Posted: Fri Jun 12, 1998 5:05 pm
Original Posted By: Janine Sunlin
Ok then how much does it cost to build an "A" engine for the piet.Still wanna build one.Steve________________________________________________________________________________
Posted: Fri Jun 12, 1998 9:22 pm
________________________________________________________________________________Send reply to: Pietenpol Discussion > Ok then how much does it cost to build an "A" engine for the piet.> > Still wanna build one.> SteveHow good of a scrounger are you? };-) I did an engine completely with new pistons and valves for about $1000 Cdn. but that was 12 yrs. ago________________________________________________________________________________
Posted: Sat Jun 13, 1998 5:19 pm
Original Posted By: joe czaplicki
Steve W wrote:> Ok then how much does it cost to build an "A" engine for the piet.>> Still wanna build one.> SteveWhen I first got interested in the Piet two years ago, I talked about"A" engines with a friend who is restoring a Model A and belongs to allthe right clubs (and there are a lot of Model A fans out there).I gotthe impression the Model A engines are plentiful, and that there is arather large group of folks supporting these engines. ie, there is muchcurrent help and information to be had.I came away with the conclusion that I could probably get an "A" in goodrebuilt condition for around $1500. Then I'd have to do the aircraftconversion.I never went beyond that point with the "A" since I decided to go the"non-A" route with my aircraft. However I did begin to suspect thateven in 1998, and Model A engine might be one of the best bargainsaround in aircraft engines!Dick Winkel________________________________________________________________________________
Posted: Sun Jun 14, 1998 9:02 pm
>Ok then how much does it cost to build an "A" engine for the piet.>>Still wanna build one.>Steve>If it's any help to you. there's an outfit in Skokie Ill called AntiqueEngine Rebuilding, tel # 847-674-6716, that will rebuild a Model A or Tshort block for $1195.00. They've done several Pietenpol modifications(cut-off & drill crank for mag adaption & face off timing gears) for anadditional $123.00.A good outfit to deal with.Happy BuildingJoe CZion, Ill>________________________________________________________________________________
