Pietenpol-List: Re: Welding
Posted: Thu Jun 18, 1998 5:28 am
Subject: Pietenpol-List: Re: Welding>>Hey Guys- I was just wondering if anyone has,or has used the Henrob>>2000 torch(or Dillon torch>>Yup. It took a little getting used to after learning>with the Victor and Harris torches used in the workshops>at Lakeland. However, it's a great torch. That soft,>narrow flame puts the heat exactly where you want it,>and it's very controllable. The one inherent problem>is the pistol grip. In a tight cluster, it sometimes gets>in the way. It also puts your had awfully close to the>heat when you are using a big flame. You can live>with it.>>Of course, the other disadvantage is the price. However,>it does not look so bad when you consider the cost of>tips for other torches. With the Henrob, you get them all>with the kit. The smallest tip is almost good for jewelry.>The largest could probably be used for rebuilding bulldozer>blades; one guy told me it was even too big for that.>>One hint: If you do go with the Henrob, pick up an extra>#1 tip, and open it out with a #72 drill. The #1 tip is just>a bit too small for .035-wall tubing, while the #2 is too>large. The modified tip is perfect.>>Also, you might consider the Harris aircraft-style torch.>They now offer a special mixer and tips that give a>Henrob-style flame on a traditional torch. I recently>bought one instead of the Henrob. Have not had time>to use it yet, but I have seen it in action, and it looked>very good indeed. I like the pencil-bodied torches a>little better than the pistol grip and saw no reason to>buy a cutting head I did not expect to use.>>But if you do buy a Henrob, I doubt you'll be sorry.>>Owen Davies>>________________________________________________________________________________
