Pietenpol-List: Notes on Piet+Corvair+PSRU (long)
Posted: Fri Nov 20, 1998 5:18 am
Original Posted By: "D.J.H."
Subject: Pietenpol-List: Notes on Piet+Corvair+PSRU (long)>For the few of you that are interested in this subject, I've learned a bitmore>over the past couple of weeks. Just thought I'd pass it along. I recentlyhad>a phone conversation with Bob Sheffield, who appeared in the mailbag of the>BPAN #60 with the announcement that he had completed building up a Corvair>engine with a PSRU. In fact, he and a friend of his had each assembledCorvair>mills with their own version of the Rinker Drive. He had strong opinions.>First of all, he confirmed that the VW reduction gear that is used in the>Rinker Drive must be from a Type 2 VW (transporter, kombi, single cab,etc.)>from between 1964 and 1967. Not sure why earlier or later models cannot be>used, but it could be because the '64-'67 have the thickest shafts (13/8").>Now, these aren't so hard to find. I've learned that everyone who has aType 2>from this era wants to get rid of their transaxles for some unrelatedreason,>and the guys that build dune buggies collect these for installation intheir>baja bugs. They seem to be a pretty good source. The problem is thatthere>were 3 different gear ratios built during this period, and the rarest isthe>one most suited for our purpose. It's known as the Mountainous Terraingear>ratio, 19 teeth on the drive gear and 27 on the driven gear, for areduction of>1.42 to 1. However, the most common reduction box has a ratio of 1.39 to1.>>Bob Sheffield assembled his unit with the 1.39 : 1 gear, and he's veryhappy>with the engine performance, although he has not yet flown. Says it startson>the first pull every time. He's turning a 72" prop, but doesn't yet knowthe>pitch. Other characteristics of his engine which diverge from thePietenpol>conversion are:>1. He removed the fan, alternator, and harmonic balancer (running andimpulse>mag).>2. high capacity oil pump.>3. 140 hp motor>4. Cast aluminum oil pan>5. get this...a carburetor from an old outboard motor (from a boat) on a>four-legged intake manifold above the engine.>6. Did not adjust engine mount; he figures the 3 inches gives him moreprop>clearance.>>In case you're not convinced that this guy really wants to stretch thelimits>of the Pietenpol classification, he's building this as a Chad Williebiplane.>He says he'll send me some photos, so I'll scan 'em when they arrive.>>I also received a response to questions that I posed to Jim vanDervort. He>built a Corvair/Pietenpol with a Rinker Drive many years ago. I don't knowhow>many hours he has on it, but the last 225 hours have been without the PSRU.He>said the disadvantages are the added weight (nearly 50 lbs) and added>vibration. Bob Sheffield and his friend avoided much of the weight bycasting>the gear housing from aluminum, instead of using the standard VW cast iron,and>their thrust bearing has eliminated vibration. Since Jim removed the PSRUfrom>his ship, his climb rate has decreased (take off distance went from 400 ftto>800 ft...he's a BIG guy), but top speed is about the same. He's says he's>still faster than nearly every other Piet he's flown with. Never heard of>anybody with problems related to thrust loads on the crankshaft.>>So, that's what I've learned so far. I still don't know if I'll continueto>pursue this PSRU idea. Sounds like advantages are just about equal to>disadvantages.>>--Peter>>________________________________________________________________________________
