Pietenpol-List: VW Info
Posted: Thu Jan 07, 1999 7:01 am
Original Posted By: Andrew.Pietenpol(at)stpaul.com
Subj: VW Engines Date: Fri, Jul 24, 1998 11:57 AM EDT
Pietenpol-List: Re: VW Info
Posted: Sat Jan 09, 1999 11:40 am
The VW doesn't produce the same hp as a C65 at the same RPMThe VW produces more or less depending on which VW you'll talkingabout at higher RPM'S. Because the faster the prop turns the closerthe props tips get to mach1 this ain't cool rather noisey I'm told so theprop is limited by this, the faster the engine turns the smaller the propdiameter must be to limit tip speeds. There have been lo'ts of caseswhere more powerfull engines were installed and the performancegot worse. The reason is that the higher rpm used a smaller diameterprop It's thrust optained from a smaller colume of air moving back ata much higher velocity, this air was now moving faster and closer tothe fuselage and in a plane such as the PIETENPOL with lot's andand lot's of parasitic drag and you guessed it there was less thrustbecause of all the increase in drag. Now take the older Ford enginelow on super tech but high on cubic inches and probaly a long strokein the crank lot's of torque and power at lower RPM and a long propproviding a wider colume of air moving back along the plane at a lowervelocity. The VW would work if it had a reduction drive and calulated thebest cruise rpm for the engine rpm. Gotta go now got expoxy warming in front of a wood stove anda rib ready to be glued.________________________________________________________________________________
Posted: Sat Jan 09, 1999 10:06 pm
In a message dated 1/9/99 11:40:05 AM Central Standard Time,rrobert(at)centuryinter.net writes:<< For more Pietenpol informationDoes anyone know the address for this site ?Chuck________________________________________________________________________________
Posted: Sat Jan 09, 1999 10:53 pm
Original Posted By: "Gerard "Larry" Huber"
And...www.pietenpol.comRon E. ________________________________________________________________________________
