Pietenpol-List: Gear/Seat Belts
Posted: Tue Jan 19, 1999 7:41 am
>1. For the Jenny style gear builders; did you use rivets as called for, or>bolts on the landing gear?Phil- I used 3/16" AN hardware. I had my wood gear on and off about 3 timesduring the building phase so the bolts got a workout.>3. I haven't seen any discussion on seat belts and/or shoulder harness. >Does anyone have pictures or details to share about attach points etc.?Lots of Piet builder's do have shoulder harnesses but in my case I left themout due to literature which indicates that unless you can mount the attatchpoints above shoulder level you may induce spinal compression during anaccident. This is another one of those research and ask questions, thendo what's best for you. Mike C. ________________________________________________________________________________
