Pietenpol-List: imspections
Posted: Fri Jan 22, 1999 8:01 pm
Original Posted By: Borodent(at)aol.com
Greg wrote:What are the legalities about work on the aircraft or modifications? IfI'm not the original builder but the current owner of a homebuilt. CanI do the work or do I have to have a A&P do it>>If you are not the builder all significant airframe & engine work must be done by either the builder or an A&P.An interesting item is that if you are the builder & the aircraft has acertified engine you may work on the engine & it still remainscertified.Mike B ( Piet N687MB )Greg wrote:What are the legalities aboutwork onthe aircraft or modifications? IfI'm not the original builderbut thecurrent owner of a homebuilt. CanI do the work or do I have tohave aAP do itIf you are not the builder all significant airframe engineworkmust be done by either the builder or an AP.An interesting item is that if you are the builder theaircraft has acertified engine you may work on the engine it still remainscertified.Mike B ( Piet N687MB )________________________________________________________________________________
Pietenpol-List: Re: imspections
Posted: Sat Jan 23, 1999 11:38 am
Original Posted By: Kyle Ray
I> If you are not the builder all significant airframe & engine work must be > done by either the builder or an A&P.> > An interesting item is that if you are the builder & the aircraft has a > certified engine you may work on the engine & it still remains certified.> > Mike B ( Piet N687MB )> > I do not beleive that this is correct. As the owner of an experimental(homebuilt) you can do any work on it yourself. However you cannot do theannual conditional inspection on the aircraft unless you are the builder andhave applied for the repairman's certificate. You must have either the builderor an A&P or IA do the annual conditional inspection.Scott ________________________________________________________________________________
